Question about Air Tools & Compressors
Manual for husky air compressor ''easy to go''
Need to figure out how to use the husky air compressor and which attachment would be used for stapling.
  • 2 more comments
  • Anonymous Mar 15, 2014
    How to replace a belt on a husky portable air compressor
  • Anonymous Mar 16, 2014
    I need a manual for a Snap on air compressor model: BRA1780V.
  • Anonymous Mar 18, 2014
    60GAL ELECTRIC VERTICAL COMPRESSOR WILL NOT TURN OVER, POWER GOES INTO MOTOR
    husky vertical electric air compressor will not start, power to motor ok but will not turn over
  • 55 Answers
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
How do you take the plastic body apart to fix broken electric cord? I got all screws out and it doesn't want to separate.
Posted on Jun 21, 2011
Have huskycompress 26 gal does it have pressure level that it will turn off on
Posted on Jun 18, 2010
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
    Free Husky Air Compressor User Manuals ' ManualsOnline ...
    powertool.manualsonline.com > ... > Husky > Power Tools Husky
    Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
    Sep 04, 2015 | Air Tools & Compressors
    Can you use staples with this?
    read the manual it probably tells there but I doubt it .
    Mar 11, 2015 | Husky DP Series 18-Gauge 2 in. Brad Nailer...
    Can u put air in a tire with this type of compressor - the husky easy air air compressor 1.5 gallon y1000
    Yes, you will need a tire chuck to add air in the tire. And don't over fill the tire, okay?
    Nov 29, 2014 | Air Tools & Compressors
    Husky 26 gallon air compressor parts
    well it depends on what you actually need because husky doesn't make the compressor, it's branded
    Dec 15, 2013 | Air Tools & Compressors
    Need manual for husky air compressor H1820F
    Ask here, they may be able to help http://www.about-air-compressors.com/husky-air-compressors.html
    Sep 16, 2012 | Husky Air Tools & Compressors
    Husky 60 gallon compressor switch from 220 to 110
    Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
    Jul 28, 2012 | Air Tools & Compressors
    I have lost my manual to a husky pro 60 gal.air compressor and I need to add more oil, can someone tell me what oil ,seems that i used synthetic 10-30 initialy
    either use air compressor engine oil,. or search out a new owners manual from online,. the details will be in there..
    Best regards
    Ck
    Jan 05, 2011 | Campbell Hausfeld Air Tools & Compressors
    Air Tools & Compressors Logo
    5,381 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
