Question about Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 3 USB Ports not functioning
My laptop 3 USB ports use to be working, then stopped for several months, then started working all of a sudden for about 5 months, and have stopped again. If there was a loose wire can you recommend where it might be internally? Thanks.
  • Guymmo Mar 25, 2008
    The three USB ports appear dead.
    The touchpad (internal USB device) continues to work.
    Linux:
    Booted from a Linux CD and the ports do not work under Linux either. According to what I understand about the BIOS of the Toshiba 5005 series all device settings (at least for the USB) are in the operating system and none in the BIOS.
    So it appears that the (external) USB problem is not software.
    Windows-XP:
    After restarting in Windows-XP and disallowing and uninstalling the USB device driver (2442) and multiple rebooting: the USB ports came back!
    But two reboots later I lost the ports again. (Touchpad still okay).
    My conclusion so far is that this is an intermittent hardware problem. Hope that you have some suggestions, thanks.
  • bezay Jul 12, 2008
    my usb ports do not function
  • 4 Answers
Sory, I know this topic is old but I have (almost) the sabe hardware (mine is a 5005-s507) with the same problem: usb ports are dead and in my case the LAN port is dead too.
So, at first i was convinced it was a problem in the southbridge chip but the touchpad (witch is PS2 and not usb as mentioned) still works so I give up from this theory...
Well... opening the laptop I saw there is two USB ports soldered to the sound card and one along with the video card. This two cards are not integrated to the main board (and can be replaced) but the LAN card is integrated and than I'm back to the mark zero.
Theory1: despited to de LAN card be onboard, the conector itself is not. It is conected through a short set of wires to the mainboard. So could it be a problem with the USB controler HUB (forgive me if I ame being nonsence) associatd with a defective LAN port? two problems?
Theory2: a malfunction in the motherboard, not on a chip but in a circuit ramification, due to some Resistor, Capacitor, Inductor causing current to be unistable or insuficient?
both cases demands the mainboard to be replaced.
Is important to mention that the sound works and as it is conected throug the PCI bus witch is conected to de southbridge, I discarded the possibility of complete fail of the Southbridge chip.
Posted on Jun 04, 2010
    President:
  • 2,961 Answers
I don't think a wire is the problem as they are soldered to mobo. It is more than likely a power problem. If you go to the hardware tab in device manager and go down to usb root hub>right click and properties then look at the power tab and you will see a 500MA allowance on usage. You can easily go above these if you are using them, so check that they are all active. Also go to control panel>admin tools>services and look down list for 'plug n play' and make sure it is set at automatic and 'universal plug and play' is set at manual
Posted on Jan 29, 2007
USB PORTS NOT WORKING
try to update or download the usb cord of your laptop
Nov 27, 2013 | Toshiba Satellite C655-s5090
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
After not using my laptop for several months (it was plugged in however) my USB mouse will not work now when I boot up my Toshiba Satellite laptop.
Here are some trouble shooting steps you can try relatively easily....
If the mouse connects via a USB cable, try connecting it on another USB port while the laptop is on.
If it is an optical mouse, check to see if the LED(s) underneath are lit. Change ports until LED lights.
If you have another computer also with a USB mouse and it is working, try a mouse exchange. If the non-working mouse also does not work on the other computer and the mouse from the other computer works on your Toshiba Satellite laptop, the problem is likely with the non-working mouse.
Finally, If the non-working mouse is a wireless one, its battery may be dead. Try a new battery in it.
Feb 14, 2011 | Computers & Internet
I have lost access to all the USB ports on my Toshiba Satellite P105-S6024. Most recently - 12/26/09 - I was able to use all ports, althought my 16BB Flash Drive - Staples Relay Model also suddenly stopped...
There are a few toys and devices made in China that deadshort the USB terminals. I hope you have not bought and installed one of these. I had 2 in the shop a year ago with some Dora Explorer usb toy that toasted the usb once installed. If you have bought and installed something about the same time as the usb stopped working you will need to call the company that made the device and demand they replace your motherboard.
Dec 29, 2009 | Toshiba Satellite A105 Notebook
Usb port not functioning
Windows XP is not compatible with USB 2.0 ports. Could you confirm you have Service pack 2 or 3 installed. If not, you should install SP2, so they should work.
Jan 12, 2009 | Toshiba Satellite A100-S8111TD Notebook
USB Malfunction Toshiba Satellite A45 S120
Yeah it could be a virus or mother board might need to be replaced because your usb ports are integrated with the motherboard. First try to put a keyboard or mouse on the usb port just to test its functionality,if mouse or keyboard works,that means it could be your usb/windows registries might have been corrupted..you might need to install windows,if mouse or kbd didnt work,it could be the motherboard/usb ports
Nov 28, 2008 | Toshiba Satellite A45-S120 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
268 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
