Question about Microwave Ovens
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it works. Was repaired twice under warranty and once just out of warranty. What is the problem? Cheers Lindsay
  • dryseal123 Dec 02, 2008
    Question: I have pulled apart the front panel. The keypad is a self adhesive sticker with circuit on back. Are you saying that I should unstick the pad and clean the back of it? This was done previously and they replaced the keypad once. Could it be a circuit board problem perhaps? Cheers Lindsay
    Scholar:
  • 107 Answers
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Posted on Dec 02, 2008
  • Quang Viet HUYNH
    Quang Viet HUYNH Dec 02, 2008
    No you can not clean that film the contact are inside that film you should replace that part after you unstick the pad it call itself GRAPHIC SHEET and the part you should replace is MEMBRANCE SWITCH part number is QSW-KA023DRZZ
    Howlong ago they replaced for you depend how often do you use your MWO, howmuch it vaporised the hot air can get into this membrance if it still new then you should replace the rubber connector I will attached the files the item 3-5 part No. QCNC-A017WRZZ it cost about S15 Aus or replace both
    Let me know how you do
How do I use the grill function on my new microwave?
I've had an Emerson microwave/grill for about 5 years now and love it!! To use the grill function you just hit "grill/combo" then hit the buttons up above the grill/combo button for however many minutes or seconds you want, then hit "Start" button. make sure your using a metal dish.
Feb 20, 2016 | Emerson Microwave Ovens
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Oct 01, 2012 | GE Microwave Ovens
Maytag microwave keypad
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Troubleshoot maytag keypad control board
Oct 01, 2012 | Maytag Appliances Over-the-Range Microwave...
Hello,i have microwave KHHS179LSS-2. Display indicate code F7. I check magnetron thermostat resistance is 0 ohms. I replace 1100W inventor. Microware stil indicade code F7. Thanks for you help.
From a similar model's tech sheet (and yours should have one hidden inside):
F7
Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Check resistance of the magnetron thermostat.
4. Check the magnetron. See this file for details.
5. Check wiring to the 1100W inverter and control system. See "Checking Inverters"
6. Check operation of all interlock switches. See this text file. Check door, hinge and cavity front alignment. Adjust as needed.
7. If switches operate correctly, replace 1100W inverter.
8. If problem persists, replace electronic control.
9. Plug in microwave oven or reconnect power.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHHS179LSS2 without dashes or spaces) from the tag on the oven here.
Nov 25, 2010 | KitchenAid Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Sharp Carousel R-395F(S)
We repair those for US and Canadian customers for $39.95, but in the UK you can contact Quality Electronic Repairs. I think they repair these.
If you want us to do the work for you, you'll need to add $15 for extra shipping and as much as $39.95 for other countries.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Feb 02, 2009 | Microwave Ovens
Microwave Ovens Logo
495 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
