Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse No Power After Surge
I had a power surge at my home and my Westinghouse LCD will not turn on. Is there a fuse or fusible link that can be replaced or is it worth the effort?
  • 88 Answers
1.ya you could check the power unit.
2.also check fuse.
Posted on Dec 07, 2008
Samsung LE32A4566C2D flat screen tv wont turn on?
There is a chance the power supply is fried. However, I've seen some Samsung power supplies that have fusible resistors in the power supply for added protection. So your main fuse could be ok, but there could be an additional fusible resistor in the board as well. Also be aware, depending on where the surge entered the TV, you could also have a defective main board. Not trying to rain on your parade, but surge damage can sometimes be severe.
Dec 09, 2012 | Samsung Televison & Video
Have a 2004 owners manual. cig lighter fuse blew,dont know which one it is.
Fuses, Switches, Circuit Breakers And Relays Most vehicles use one or more fuse panels. This one is located on the driver’s side kick panel tcca6p01.jpg
It is possible for large surges of current to pass through the electrical system of your vehicle. If this surge of current were to reach the load in the circuit, this surge could burn it out or cause severe damage to the vehicle’s electrical system. It can overload the wiring, causing the harness to get hot and melt the insulation. To protect vehicle wiring, fuses, circuit breakers and/or fusible links are typically installed into the power supply wires throughout the electrical system. These items are nothing more than a built-in weak spot in the system. When an excessive amount of current flows through a circuit it causes an increase in heat throughout the wiring. Fuses and circuit breakers are designed as the weak link in the system and will disconnect the circuit to prevent damage to the components contained within that circuit. Components are equipped with connectors so they may be replaced in situations where they were damaged due to a power surge.
The following are descriptions as to how fuses and circuit breakers protect the electrical system:
  • Fuse- A fuse is a weak link in the system designed to create an open circuit when the amperage flowing through that circuit exceeds the limits of the fuse. As the amperage increases, the conductor within the fuse heats up and eventually melts and breaks apart. This open circuit interrupts the flow of current and protects the components in the circuit.
  • Circuit Breaker- A circuit breaker is a "self-repairing" fuse. It will open the circuit in the same fashion as a fuse. The surge creates heat the same way that a fuse is affected. When the surge subsides and the circuit cools down, the circuit breaker will reset and allow current to flow through the circuit. Typically circuit breakers do not need to be replaced.
  • Fusible Link- A fusible link (fuse link or main link) is a short length of special, high temperature insulated wire that acts as a fuse. When an excessive electrical current passes through a fusible link, the thin gauge wire inside the link melts, creating an open to protect the circuit. To repair the circuit, the link must be replaced. Some newer type fusible links are housed in plug-in modules, which are simply replaced like a fuse, while older type fusible links must be cut and spliced if they melt
Always replace fuses, circuit breakers and fusible links with identically rated components. Under no circumstances should a protection device of higher or lower amperage rating be substituted.
I would get a fuse tester that can test fuses while still installed and powered up. It will light if the fuse is blown when applied to the two tabs that are exposed on fuses that are installed in your Ford product.
Check the fuse box under the dash on the driver's side, and check to see if there are any fuses under the hood.
If you don't have the tool, try to look for stickers or download the manual from
Jul 31, 2010 | 2004 Ford Taurus
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Now ur tv LED power light indication on the front LCD panel flashes?Yes,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like,Ebay,com to buy a refurbish power supply board for the replacement.
Jul 13, 2010 | Toshiba 37AV502U 37 in. LCD HDTV
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Had a power surge at home and the screen the
Hi Geoff, You will need to open up your monitor. There will be a pcb fuse in the region of the mains input and you may need to replace some other components in that area which are designed to protect the monitor in just such an event as a power surge.
Nov 20, 2009 | LG 22" FLATRON LCD Monitor
We didnt have a surge protector on our tv we purchased from home shopping net. and lihtning came in the line and i guess hit our tv can it be fixed or is it worth fixing price wise i hate to throw it away...
Look at the power supply module, most of them will have a surge protection devices (called MOV, same as used in common surge power strip but cannot handle big surge that power strip can handle) installed to protect minor surge, it should blow the fuse. Once MOV blown, it will more likely stay short circuit, if you put the new fuse in it will blow the fuse right away. You need to see if the MOVs blew up any sign of blown up components.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
After power will not turn on
that will affect the power supply, check for any open fuse at the early stage of the input current, other than that you need to replace the power supply board by a new one
Mar 31, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
223 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
