Question about Apple Power Mac G5 Desktop
External sound problems on Power Mac G5
When using external audio (firewire, usb audio device) the sound is echoed and useless, BUT using internal audio everything sounds fine.
Can you help me?
  • 6 more comments
  • sonorafx Dec 28, 2008
    I have a TASCAM US122 mixer (USB) and a JVC miniDV cassette deck (firewire).
    On both devices the sound is useless using SystemPrefs>Sound>Output, only internal audio works fine.
    The OUTPUT is echoed and I use FCP studio but I noticed that even quickime and itunes doesn't work with external audio.
    I re-install drivers, check the devices on other machines (no problem) but I don't know what is happening.
    The problem appears about a week I upgrade my system from 10.4 to 10.5x.
  • sonorafx Dec 29, 2008
    You're right, I have the G5 then the Tascam then an Amp with speakers, in fact, it's an old RCA Home Theater on which I have connected the Tascam (Tape) the MiniDV (VCR) and the G5 speaker out (CD). If I switch to one of those inputs (except CD) the sound is echoed.
    It's wierd because I always have that setup, as I told you just a week before the upgrade to leopard that thing happens. It's not only the Tascam but the deck.
    PS. English is not my native languaje so please forgive me If I'm not as clear as you may wish :)
    By the way THANK YOU VERY MUCH for your interest
  • sonorafx Dec 31, 2008
    Yes I did the update right after the installation of leopard and everything works fine, the problem appear suddenly, on both firewire and usb devices.
  • gpmnn Jan 18, 2009
    Yes I have the same problem in my G5 Mac the output speaker will be noicy when i connect earphone. why is that reason
  • Sean Cole
    Sean Cole May 11, 2010
    Hi again,
    So did you use the updated drivers from the tascam site?
    Cheers
    Sean
    PiDigital.co.uk
  • Sean Cole
    Hi Sonorafx again,
    I'm going to assume that you've already downloaded the latest 3.40 drivers for the US122 available from here:
    http://www.tascam.com/i-716-232-128-1-3B...
    This is essential for OSX10.5
    I need to clarify a bit more with you:
    • Your setup is G5 via usb to the tascam then using the output from the Tascam via line out to your amp and speakers
    • You've tried with both the 'Direct' switch on and off
    • In the SystemPrefs>Sound>Output and Input settings it should display the TASCAM US122 in both lists
    • Because an echo is nothing more than a digital or analogue delayed feedback loop, make sure that all inputs are disconnected and that the input levels in the systemPrefs are set as low as possible. See if that makes any difference.
    I look forward to hearing back from you.
    All the best
    Sean
    PiDigital
  • Sean Cole
    Hi Sonorafx,
    Can you go to SystemPrefs>Sound>Output and let us know what the list of devices are with one of your Firewire or USB devices are connected. Also knowing which devices you are trying to connect is useful. Is it the input or output that is echoing? What other software are you running at the time?
    Many thanks
    Sean
    PiDigital
Mac g5 sound output is echoing? what is the reason
Posted on Jan 18, 2009
How do you boot from an external hard drive
When you power up the Mac hold down the alt/option key. after a few moment you will get a different start-up screen. It will show your internal HD and then when the curasoe comes back it will also show you any external drives with valid start-up software on them.
Eorks with DVDs and CDs and other macc connected by Firewire in target disk mode.
Mar 23, 2012 | Apple iMac G5 Desktop
My Toshiba external hard disk does not accepting backup from mac G5
my external HDD is not letting me drag and drop files from my mac. Is this my mac being secure? If so how can i remove it so i can store audio files on this device. thanks
Jan 23, 2011 | Toshiba 120GB USB 2.0 Portable External...
When using Firewire bus to power the sound card my
It's likely that the FireWire bus isn't meeting the power needs of your card. Just use the external supply since there isn't too much you can do.
Jul 13, 2010 | Edirol FA-66 Sound Card
I purchased a JVC BR-DV600U DV deck to use with my Mac computer for video editing. When I plugged the Firewire cord from the deck into the computer, problems began to happen. Two of my three external...
There exist a number of methods for dealing with FireWire device interference, a few of which are explored here. Switching Ports The first procedure you should try when experiencing a problem that you believe to be caused by device interference is to simply reconfigure the arrangement in which your FireWire peripherals are connected. Try switching each device to a different port, or temporarily disconnecting one or more of the devices. In particular, if you are a PowerMac G5 owner, trying switching devices from the front to back ports or vice versa. Adding an external hub In some cases, it appears that FireWire devices are not drawing enough power from the computer. This can cause a sundry of strange issues, including apparent conflicts between devices and unexpected power-offs during device operation. In these instances, adding an externally powered FireWire hub can clear things up. One of the reasons an "under-powered" situation can occur is that different Mac models have varying power capacities available through their FireWire ports. PowerBooks and iBooks have the least, generating around 7 watts. The iMac G5 also generates a relatively low amount of FireWire power, sharing 8 watts between its two FireWire 400 ports. The Power Mac G5 shares 15 watts between its one FireWire 800 port and two FireWire 400 ports. Place devices on different FireWire busses/Isolate the iSight Similar to the above procedure, adding another FireWire bridge -- via an extra PCI-based FireWire adapter or another means -- can eliminate conflicts from devices that reside on the same bridge. Power cycling the system Simply cycling the power on your system may be enough to temporarily eliminate a few FireWire conflict issues. Shut down your Mac, and disconnect all FireWire devices as well as the computer's power cord. Leave the system off for about 10 minutes, then plug it back in. First turn your Mac back on, then re-attach the FireWire devices one at a time and check for the conflict to resurface. Disconnect specific FireWire devices (especially iSight) to check for conflicts As noted above, the most common cause of interference is Apple's own iSight. In case after case, simply disconnecting this single device has eliminated problems with other FireWire devices. Other devices often implicated in FireWire conflicts include video-related devices; cameras, the EyeTV, video decks, etc.
Disconnecting the iSight has proved particularly successful for an issue where the iPod disappears from the Desktop and from the iTunes playlist, while the iPod status screen cycles from the Apple logo to a "Do not Disconnect" message over and over. The exact reasons why the iSight causes more than its fair share conflicts with other FireWire devices are many, and sometimes unclear. One potential source of conflict, however, could be the unit's high bandwidth usage. The iSight captures video at a 640 x 480 pixel resolution, at 30 frames per second in millions of colors. Such throughput uses a significant chunk of the standard FireWire port's 400 Mbps bandwidth. As such, when other devices are connected, the bandwidth requirements for satisfactory performance may not be met. Try disconnecting all FireWire devices, then adding them back one by one and repeating the originally failed operation to check for conflicts. Apply the latest updates Make sure that your FireWire drives are using the latest firmware (check the manufacturers' Web site) and the most recent iPod update has also been applied. Of higher importance, if you have an iSight, is the iSight 1.0.2 updater. In a large number of cases it has resolved conflicts caused by the camera. Re-apply the most recent Mac OS X combo updater In some cases, re-applying the most recent combo updater can resurrect seemingly defunct FireWire ports and allow devices -- drives included -- to be recognized again. The most recent combo updater is available from Apple's download page. Clear caches Try using a tool like Tiger Cache Cleaner or Cocktail to remove potentially corrupt system caches. Restart, then check if your FireWire devices are recognized.
Feb 05, 2010 | JVC BR-DV600U Mini DV VCR
My internal DVD-RW has stopped working ? Power Mac G5
Sounds like the DVD has broken. I would suggest either buying an external dvd drive (either USB or Firewire) or you could replace the internal DVD drive see instructions at http://support.apple.com/manuals/#powermac
Oct 13, 2009 | Computers & Internet
My Apple G5 and WD Passport 500Gb don't mount
You need to determine whether the problem is at the disk interface or at the computer interface. Will the drive mount on ANOTHER machine using FireWire? Will your computer mount ANOTHER device using FireWire? This will tell you which machine is at fault. It's not unheard of for the FireWire channels in a Mac to just go bad, and (unless it is a Mac Pro) it typically requires a logic board replacement to address. For a G5, this would not be cost-effective. On the other hand, as I say, it could just be a bad interface in the drive itself. It's up to you to determine which it is.
Sep 20, 2009 | Apple iMac G5 Desktop
Audio quality very poor - reverb ?
Go to control panel + sounds and audio devices + advanced
Make sure the speakers are set for laptop stereo.
Feb 25, 2009 | Acer Aspire 3003WLCi Notebook
Firewire ports malfunction
Boot the machine from external hard drive with known good OS installed.
If issue persists then, then logic board has issue.
Dec 13, 2007 | Apple Power Mac G5 Desktop
Lacie 1000gb external drive
I own a Lacie product that does the same thing. It uses firewire but it was clicking a few times and then would not display as a drive. I moved to another computer (with a different firewire card) and it worked. I decided that the firewire card was the issue at the time, but the card still read other devices like digital video camera. I know you are using the USB 2.0 cable. Can you try your drive on a different computer? That would narrow the possible solutions down.
Jun 26, 2007 | LaCie (300951U) 500 GB Hard Drive
Saying disk not readable
you could try a repartition / reformat, if the drive is detected at all, or you could try running scandisk/disktools, to try and recover / repair the TOC/ FAT
Apr 11, 2007 | Ultra 1 Bay USB 2.0 External Drive Case
Apple Power Mac G5 Desktop Logo
544 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
