Question about Hitachi DZ-MV230A DVD Camcorder
Error message 0280
I get an error message 0280 when I try to turn the camera on.
  • 2 more comments
  • Jhynx Nov 04, 2007
    Error 0280 on screen after DISC ACCESS is flashed for about a minute.
  • gneumann Jan 03, 2008
    It's causing me all sorts of problems. I've lost too much crucial footage. It has been haphazard as the disk will once say to restart, then next to insert a disk and then error code 0280 comes up. Then, (like right now) it suddenly accesses it and I can go to disk navigation but if I try to finalize it ... error code... aaaaaagggggggghhhhhhhh!!!!!!!
  • winch Mar 26, 2008
    when i try to turn the unit on it will usually say restart or error message 0280 or 2881, i have tried different batteries, different discs and running directly of the mains power supply with no improvement.
    very frustrating aaaaaaahhhhhhhgggggg
  • rhodyman Jun 11, 2008
    I too have the same problem. I called Hitachi and they gave me the name and number of a dealer in NY who may be able to fix it (I'm in RI). The dealer wants $100 check up front. I'm sure with shipping and repairs I'm looking at $200+. I'll buy another (non Hitachi) camera for that price!
    I'm guessing it's a defect in their cameras. It should be covered at no charge since it's happened to many customers. I just sent Hitachi an email. I'll let you know what happens.
I have been having the same 0280 problems mine, did you or anybody come up with a solution to this frustrating problem
Cheers Brett
email: brett.williamson@winchhire.com.au
Posted on Mar 26, 2008
SOURCE:
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
Hp nx9010 error 280
Here is the info for the error 0280
0280 Previous boot incomplete-Default configuration used
Previous POST did not complete successfully POST loads default values and
offers to run BIOS Setup If the failure was caused by incorrect values that are
not corrected, the next boot will likely fail This error is cleared the next time
Here is the direct link to the Maintenance and Service Guide
http://bit.ly/gBwWBa
Good Luck
Mar 07, 2011 | HP Compaq nx9010
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Disk error 0280
Error 0280 on Hitachi mv350a DVD camera : It looks the dvd had bad spots that could not be read. After getting frustrated trying to get any info from Hitachi manuals and support, I just decided to try to extract the data directly from the dvd(fujitsu dvd-r disk). Since my DVD was not finalized I could not copy the files directly using Windows Explorer, so I tested several applications and here it's what worked for me: I downloaded isobuster (www.isobuster.com), and I was able to view the tracks on the dvd, then I used the "Extract" option to create an image directly from the faulty dvd and it created a couple of files with the extension .ibq. I checked these ibq files and two of them were huge, so I assumed those were my video data. I renamed these files from *.ibq to *.vob(isobuster has options to extract these "image files", but you need to register it first...), anyways I tried to open these new vob files with PowerDVD and they PLAYED JUST FINE :)! Finally I just used a DVD editor to load the new .vob files and I burnt a new DVD. I hope it will save you guys some time... Mihai from Romania :)
Oct 09, 2009 | Hitachi DZ-MV380A DVD Camcorder
Error 0280 ?????
The manual would be :-
http://safemanuals.com/user-guide-instructions-owner-manual/HITACHI/DZ-MV580E-_E
On the RHS, there would be an option to Download the complete user guide.
Once clicked, you need to put the verification numbers on the screen and save to your dekstop.
Any further help, let me know.
Thanks for using "Fixya".
Jun 16, 2009 | Hitachi DZ-MV580E DVD Camcorder
Error Code no.0280
sounds like the wrong media in the disc drive ex. dvd-rw will only take dvd-r and dvd-ram disks if that helps anyone have a link for the drivers and or the install disk for this camera plz post
Aug 22, 2008 | Panasonic VDR-M70 DVD Camcorder
Panasonic
MAKE SURE YOU ONLY USE RAM AND -R DISCS IN THIS UNIT. IF THIS CONTINUES THEN THERE IS A LAZER OR LAZER BOARD FAULT.
Feb 21, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Error 0280
Replace the CMOS battery and reset the BIOS to default settings. This will resolve the issue.
Jan 27, 2008 | Hitachi DZ-MV730A DVD Camcorder
Hitachi DZ-MV230A DVD Camcorder Logo
266 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
