Question about LG WM2042 Front Load Washer
Uneven load My washing machine (Tromm WM2042CW) has recently been stopping, saying "OE". Does anyone know what that means?? I don't have my manual!
  • briankeranen Feb 19, 2009
    My washing machine will not spin on the spin cycle and keeps saying OE. I have tried about everything and it keeps doing it.
For my washer it means the drain hose is bent/ clogges or the drain filter is clogges
Posted on Mar 03, 2009
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The washing machine quit and an error code of "OE" was showing....what does that mean?
When mine does that, I stop the cycle, and untwist or remove something that made the load unbalanced and start over again. THat has always fixed it for me.
Aug 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
NEC Washing Machine when it comes to spin cycle stops and just beeps with the 'OE' light flashing.
Well, what does that mean? Old Engine? Octopus Entering? Oily Electricity? Darn. No clue from that light, is there?
My guess is that it thinks there is an uneven load. Assuming that you've straightened your load, I'd say it must be a bad uneven load sensor. And unfortunately I don't know where that is located. So I guess I'm not much help. Sorry.
Jul 16, 2008 | Washing Machines
LG WM2042 Front Load Washer Logo
388 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
