Question about HP Media Center M370N (DM163A#ABA) PC Desktop
Main fan at power is making a wierd noise
Need to know if I have to replace it
    Genius:
  • 1,061 Answers
IF IT THE POWER SUPPLY FAN YES I WOULD REPLACE ASAP.RICHARDM69
Posted on Dec 02, 2008
Fan makes noise on my Dell Inspiron One 19
Usually there is a fan on the CPU heatsink and a fan in the power supply.
Open the case and turn on the computer and use a small timber stick and poke it into the CPU fan to stop it spinning and if the noise stops then this fan needs replacing.
If it is OK the the fan in the power supply is faulty. I recommend you replace the power supply because there are dangerous voltages inside this power supply.
Jul 31, 2012 | Dell Inspiron One 19 (884116044949) 185 in...
Hi my sony vaio vgn cs36gj is frozen and making wierd noises from the fan it frozen on the desktop with the start menu up the desktop has also gone a bit pale also cnt do anything on it it wouldnt even...
possibly yes. this sounds like its overheating and locking up. need to know what operating system you are running and whether you hear the fan running or not
Jan 28, 2011 | Sony VAIO Notebook
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
2005 chrysler 300 heater fan is making noise
yes it is. most heater fans on chrysler products are real easy.you might find a dead mouse or mouse nest in there throwing fan off balance
May 08, 2010 | 2005 Chrysler 300
When i use it it makes a wierd grinding sound
Take the computer to a qualified technician, for professional trouble-shooting (failing bearings in a cooling-fan, or a disk-drive about to die).
Apr 05, 2010 | Compaq Presario Notebook
One of my fans has started making noise, how much time do i have to replace it? Am I right in thinking that it making noise that it needs to be replaced?
fan noises are usually caused by worn out fans. but can be also caused by IDE/power cables hitting the fan blades. you will have to open up the computer to see where the noise comes from.
if it is a faulty fan, replace it sooner than later as it will get louder and louder. then stop making noise all together when the fan fails.
Dec 09, 2009 | Dell OptiPlex GX270 PC Desktop
I've got a Danby DPAC 8399-4 portable heater/air conditioner. We usually use it as an A/C but we're trying to use the heater for the winter; we just brought it out of the closet. The fan barely works (and...
Check for obstructuions in the fan housing that may be hitting the fan blade, causing the noise and improper air flow.
Improper air flow will cause the uniot to overheat quickly and it will shut down on its high temperature limit switch.
You may also have a bad fan. Bad bearings will make a bad noise as well. Thios will cause the same symptoms described above.
Check for abstructions, if you can find one, remove it, if not replace the fan. You can usually reset the limit by simply turning off power and turning it back on after 10 min.
Dec 06, 2008 | Danby DPAC8399 Air Conditioner
Clicking noises
check to make sure the wires going to the main fan are not hitting the blades.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Feb 20, 2007 | Samsung SlimFit TX-S2783 TV
HP Media Center M370N (DM163A#ABA) PC Desktop Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
