Question about SanDisk Sansa e250 MP3 Player
M sandisk Keeps restarting
My sandisk 4.o gigabite wont go to the amin menu...it just bkepps restarting how do i fix it?
My LG TOUCH ME FM37 becomes dead when i'm updating its firmware for mp3 player from internet, suddenly breakup in my network connection and updating was unsuccesful and it stop working from that time.
Please help me.
Posted on Dec 02, 2008
My vivo TV is having a fit it keeps changing channels and jumping into menu and scolding up and down it worked fine yesterday never had any issues before
Teh amin system control memory IC to this TV is faulty. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 24, 2015 | Televison & Video
Sandisk Sansa View 16GB Won't Start
if it is detected in your system,use sansa updater to upgrade the firmware.You will find it here
If not, first download the firmware from here 1.Turn on the View
2.Put the device in Hold (move Hold button until orange is showing)
3.Press and hold the Left Button
4.Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
5.Wait for View drive(s) to mount
6.Extract the downloaded zip file and transfer all the contents to the mounted drive.
7.Disconnect the Sansa View and let it restart. 8.Upon completion of the firmware upgrade, the device will restart. If the restart does not initiate or complete, press & hold the Power switch for 8 seconds to reset the device and then release and press again to restart.
Sep 03, 2009 | SanDisk Sansa e250 MP3 Player
My sandisk Keeps restarting
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa wont turn on :(
Try taking it back or calling the company where you got it from.Unless of course you got it off of ebay then contact the seller.
Mar 15, 2008 | SanDisk Sansa e270 MP3 Player
For God's sake help me!!
MAKE SURE YOUR SANDISK IS PROPERLY CONNECTED TO YOUR COMPUTER THEN-GO TO YOUR START MENU-CLICK ON CONTROL PANEL-THEN CLICK ON SOUND SPEECH AND AUDIO DEVICES ON THE BOTTOM CLICK ON PORTABLE MEDIA DEVICES AND FOLLOW THE STEPS YOU COMPUTER GIVES YOU. GOOD LUCK AND I HOPE I WAS ANY HELP TO YOU.
Jun 30, 2007 | SanDisk Sansa m250 MP3 Player
Sandisk e200
its just startup issue remove all the songs and u might see reset ... and see
Jun 26, 2007 | SanDisk Sansa e200 MP3 Player
My Sandisk shuts down on me
Go to your menu screen by briefly pressing the power on button. Then hold the power button while in the menu. This will re-start the player and it should fix your problem. If this doesn't work, contact technichal support. =)
Mar 09, 2007 | SanDisk Sansa e250 MP3 Player
Sansa m230-just repeats startup message and wont continue
get a new MP3 player it is garbage there are somethings you can fix and that my friend is not one of them :D ~Grim
Jan 10, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
77 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
