Question about Video Game Consoles & Games
I dug out my old ps1 got everything together and when I start it the screen on the tv remains blue. The television is on the appropriate channel. I can hear the console working inside but can't determine if it isn't reading the disk or if the audio/video output isn't working correctly
  • sipwizdom Dec 02, 2008
    actually, i just took it all apart and it happened to be the a/v connection inside... Thank you for being prompt on your answer though! Now I can continue my FF8 adventure!!
  • 82 Answers
The blue screen makes me think that it is on the wrong input. You said channel. If you plug it into the composite inputs then it will be called "video 1" - "video 4" or however many inputs you have. So make sure again its on the correct input, and make sure that the cable you are using is clean. You can clean it using rubbing alcohol or something. Even if that game doesnt work it should have a PS1 loading screen
Posted on Dec 02, 2008
  • Casey
    Casey Dec 02, 2008
    FF8. sweet
How to connect ps1 to my tv.?
These are AV connections! When connected with the component phono leads turn on TV, then turn on the PS1 then select AV on the remote to select the AV channel!
Nov 21, 2014 | Televison & Video
My 47 in. Samsung flat screen hd tv has a picture but its a little dark then goes in and out of blue to green to red. It gets a good picture though. And the channel numbers blend together when I flip the...
Hello, I'm sorry to yell you that the lcd display (screen) is bad. Usually one side looks close to normal, and the other is dark and the picture drags and looks smeared. The cost to replace the lcd display is more than you can buy another set for, sorry. thanks, Terry
Oct 13, 2012 | Televison & Video
I have a 40" Dynex TV
You have a fault in your video circuit, a proper diagnoses will need to be performed to tell where the problem is occurring.
Sep 20, 2012 | Dynex Televison & Video
Blue screen says no signal. how do I change the source without a remote?
usually there are buttons located on top or side of tv, click on the main or menu button, and change the tv input to appropriate channel, refer to owner's manual make sure it is not on video1 or aux 1 as this may cause the blue screen, if there are no buttons, you will need to get or borrow the remote corresponding to that television, if using a universal, check the code you will need for that tv.
Oct 17, 2010 | Durabrand BH1304D 13" TV
Panasonic TH-42PX75U Blue Screen
This could be a reception problem of the cable transmission or the cable box if used. Are you using cable or SAT box. Tv goes to blue screen if signal is weak automatically.
Dec 03, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Magnavox 51" Model # 51MP392H/17 Color problems
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Sep 30, 2008 | LG 42LC2D 42 in. LCD HDTV
No picture, just an abstract pattern
it depends if its just that input or the whole tv itself if it works on other inputs it may not be to bad to fix, but if its the tv itself it depends on how old it is and how much you paid. it could wind up costing quite a bit. so take all those things into consideration. it might just be time to upgrade
Jun 05, 2008 | Sony KP-53HS10 TV
Connevting to an LCD TV
Dear Customer,
try to do on av channel that provides special output like ps,live footage connected to spy cam,xbox & any other like tuner-capture card all are acceptable on av channels,
TRy & having funn with your new lcd,
THNX
May 17, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
Video Game Consoles & Games Logo
96 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
