Question about HP LaserJet 3015 All-In-One Printer
HP laserjet M1319f MFP "no fax detected" error
Keep getting a no fax detected error when sending faxes. fax never goes through. please help.
  • 8 more comments
  • Anonymous Dec 17, 2008
    I have the exact same problem!!!
  • Anonymous Jan 21, 2009
    I have the same problem using embarq. No fix yet :(
    I have the same problem also. I had a spare fax machine (canon) so i removed the HP and used the canon and we were able to send and receive faxes without any problems. I have spoken with HP and they are going to replace this unit for me as they think it has a problem with the communication port. To be honest i don't think this will fix the problem but it's worth a try.
  • abautista Jan 21, 2009
  • shuyu_63 Jan 28, 2009
    I have exact problem. send fax never get through. it always tell me that on answer or comm erro or busy . I tried thousands time with different fax #
  • hphp123 Mar 03, 2009
    I have the same problem too, but not all all fax numbers, only some never get through, don't know why. but if I try to fax by a manual dial with the handset on the fax machine, then it will go through......
    Does anyone know how to fix this?
  • Anonymous Mar 12, 2009
    This machine BLOOOWS~~~
  • alice09 Apr 09, 2009
    I have the same problem "no fax detected" but can receive faxes.
  • Anonymous Apr 16, 2009
    This machine is a pain in the a$$.
  • Anonymous Mar 25, 2014
    it saying device error press ok
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Posted on Jul 24, 2009
With all settings made my HP LaserJet M1319f MFP received no faxes sent by others !
Help my please ... Thanks
Posted on Sep 24, 2009
Lowering the speed to the middle speed on the M1319F helped me!
Press the "set up" button, At the "main menu" use arrows to go to "fax set up" select (use ok button to select) "all faxes" select "fax speed" select "medium v.17" press "ok" . You should be able to receive and send now! Good Luck!
Posted on Mar 11, 2010
Data is not send or getting form fax
Posted on Oct 08, 2009
Upgrade the firmware ...all u poroblem solved
Posted on Nov 28, 2009
How to mak fax.
Posted on Jun 10, 2009
    Genius:
  • 2,120 Answers
Does it say DIAL TONE DETECTED?
If so, check the phone line with a regular phone and make sure you are plugged into the LINE port.
Posted on Dec 31, 2008
HP M1319F Stop Printing Fax Error Reports.
go to the fax repots,conformations,their u select send only.
Dec 02, 2011 | HEWLETT-PACKARD LaserJet M1319F All-In-One...
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
Sending fax
FIXED WITH THE HELP OF HP GUY BY UPGRADING THE SOFTWARE IN TO THE MACHINE.
Jan 19, 2010 | HP Laserjet M1319F Laser Multifunction...
HP LASer jet m1319f mfp errors no entries in fax log
check that it is connected to the phone line, if your phone line is working your fax system also work
Jan 07, 2010 | HP Laserjet M1319F Laser Multifunction...
My HP M1319f fax machine is having trouble sending faxes only to certain phone numbers. Is this a problem with the actual machine, or the phone line?
I have purchased the HP M1319f multipurpose machine 1 year ago and expected it to print as well as fax. Sadly to say 1 year later, the printing works as expected but the fax never worked consistently for me. The solution I found was to buy a used fax machine and only use the HP M1319f as a printer.
The problem I've read about this problem on HP forums was the fax speed of the M1319f. It is locked to 28.8k which means it is only able to communicate with some fax machines. Older machines that doesn't support 28.8 will get errors and the fax will fail. This is definately an HP problem but considering I purchased this 1 year ago, this problem will never be fixed. Avoid this printer at all costs if your considering to use the fax machine.
Oct 19, 2009 | HP Laserjet M1319F Laser Multifunction...
Fax Printing is not Clear
You can change the default font of your printer from the settings panel at the front. Carefully go through the manual and you will be amazed how easy it is to effect such changes. However, if is attached to a computer, it will call the shot as default font of the system overrides that of the printer. Good luck
Apr 27, 2009 | HP Laserjet M1319F Laser Multifunction...
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
HP LaserJet 3015 All-In-One Printer Logo
10,835 people viewed this question
Seeker5211
Seeker5211
