FixYa.com
Tags:
KLH R7000 6.1 Channels Receiver
KLH R7000
posted by snic68 on Jan 29, 2007
I never ever throw away manuals but this one I can't find.
I have a DVD player and it has coaxial output. where on the reciver do I put it. I see the coax in the back on the upper left side but it has yellow inards so I was under the impression that is was for video only?
for the 6.1 do I have to only use the 6.1 RCA jacks on the reciever or can I use the ole fashion wire inputs?
thanks for the help and great site!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 11, 2007
Thanks for Trying (70)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Nope. That's the coaxial digital audio input. Thats the one to use for your dvd players digital audio output.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 16, 2007
Not Rated (0)
NotAnIdiot
Rating: 0%, 0 votes
The previous poster has it WRONG.
Presuming your equipment follows industry-standard color-coding conventions, an RCA-type coaxial jack with a yellow insulator is for COMPOSITE VIDEO. An RCA/coax connector for digital audio would have an ORANGE insulator. It is important to NOT mix these up, as the signals are not even close to compatible -- and cross-connecting them might even cause damage to one or both units.
Your DVD player near-certainly has a COMPOSITE VIDEO output, and almost as surely, a coaxial Digital Audio output. Similarly, your receiver near-certainly has a COMPOSITE VIDEO input. But it may or may not have coaxial Digital Audio input; and even if it does, it remain questionable whether or not you'd want to use it (unless the DACs in the DVD player are particularly bad, I'd guess not).
It is also likely that both your receiver and your DVD player have either S-Video or "componennt" (or both) video inputs/outputs. If so, this would be the preferable method to feed video from the DVD player to the receiver, as the signal quality will be better maintained. OTOH, if your TV/Monitor does not also have Component and/or S-Video inputs, _and_ your receiver does not do transcoding, then you will need to use whichever connection scheme represents "the highest common denominator" between all the units.
This Problem Also Relates To: NAD Grey C720BEE High Quality Stereo Receiver Panasonic SA-HE200 6.1 Channels Receiver Philips FR965DHT 5.1 Channels Receiver Aiwa AV-D58 5.1 Channels Receiver Aiwa AV-D55 JVC RX-6030V 5.1 Channels Receiver JVC RX-D301S 7.1 Channels Receiver
Can you Help with these Receivers problems?
Audio receiver!
I'm using a KLH R7000 receiver,... Answer This...
klh r7000 no sound
i have a klh # r7000 with no... Answer This...
KLH R7000 Component Video...
Yes. I know this reciever is... Answer This...
WAS working fine but seems lost...
About a month ago had a small... Answer This...
No sound from the back.
None of the connectors in the... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
