( gateway ml3108b laptop ) when i turn the laptop on the power light comes on but the screen is blank ,
  • Anonymous Jan 10, 2009
    I have the same problem (gateway ml3108b laptop). I connected external monitor and the screen is also blank. I tried switching the output with Fn+F4, but no response.
  • rhb0105 Mar 06, 2009
    I have the same problem.  No sounds either except for the fan.  I've tried turning it on and off with the power button and using an external monitor all to no avail.
This is a GPU problem with this breed of laptop. The best way to fix is to treat it like an Xbox360 belive it or not. You have to overheat it at the GPU end (back of fan/heatsink) then press down firm but not hard over the back end of the fan. This should (worked for me) result in the BGA conatcts making a connection back to the soler pads they were meant to be attached to the motherboard.
If you are a bit more savvy with hardware i would recommend doing a reflow with a heatgun, i have not had to do one "YET" myself but if you feel you have to then go for it. The same rules basicallly apply to a lappy as they do an XBox360.
Doing a search for XBox360 Heatgun in good ol google may bring you a few pointers otherwise. Same rules basically apply to a lappy.
I deliberetly caused mine to overheat then bent the board ever so slighy whilst still hot (NOT RECOMMENDED) so the GPU made contact with the Motherboard again and it has been working fine for 5 days now, don't know when i will have to perform a reflow though.
Best of luck to you and hope this helps.
Posted on Feb 14, 2009
  • 781 Answers
1. check if your video image is being directed to the an external monitor and toggle it back to your lcd screen using fn+(function key) (it could also be shif+ function key)
*note: the function key should show a pic of a monitor, look at the keyboard and also look at your laptops's documentation.
2.if above solution does not return the picture to your laptop lcd screen plug an external monitor and redirect the image with the function key as directed above, if you do get an image on the xternal monitor but nothing on your lcd screen your lcd screen is finished
3. if you don't get any image on neither screen this could mean your video adapter on your laptop's motherboard is dead, in which case you only resource is to access your computer via remote desktop connection.
hope that gives you an idea of what to try in order to find out where the problem lies.
Posted on Dec 02, 2008
  • 55 Answers
You might need to get a replacement screen for it.
Gateway nv44 laptop screen goes blank
How do I turn on a Blank Screen of my Toshiba L500D-PSLT6C LapTop (The power is on but the screen is not)
Mar 28, 2010 | Gateway Computers & Internet
Power comes on but screen stays black
The backlight inverter board may be bad, or worst case will be bad lamp. You should look to see if the cable comes off the inverter board first. You may learn maore here:
http://www.insidemylaptop.com/category/5-gateway-laptops/
Please post back what you find.
Nov 15, 2009 | Gateway M465-E Notebook
Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Sep 10, 2009 | Gateway T-1625 Notebook
Still not working
you have a bad moterboard time for a new laptop. does it turn on at all. does it boot are there any lights that come on. if not the laptop is no good. not worth fixing. if you have a bunch of data on it you need take it somewhere and get the data put on to cd`s or dvd`s
Jul 18, 2009 | Gateway Computers & Internet
Laptop won't turn on yet on light is working
my HP pavillion Dv6646us won't turn on...its is fullycharge..but the screen remains blank. the lights that indicate that it is charging is on...but the screen....it still blank...need help..
Jul 14, 2009 | Gateway Computers & Internet
Gateway laptop ml3108b no screen coming on
this is a common fault with this laptop, the only way to repair this is to strip the laptop, remove the mother board, heatsink and fan under the heatsink you will see the nvidia chip this needs to be heated to 480C for about 5 mins only heat the nvidea chip nothing else! paste chips and replace heatsink fan etc laptop should now be fixed, remember to clean fan whilst it is out as a clogged fan probably caused the fault in the first place
Jun 11, 2009 | Gateway M305CRV Notebook
Gateway ml3108b laptop wont start up
shine a flashlight on the screen. if you see a faint image, its the backlight thats the problem and you will need to get a new one to fix that. But if you dont see a faint image you will need to hook it up to an external monitor( an monitor that is not made into the laptop) , and if you see an image on the monitor you will have to clear the CMOS.
and to do that you will need to take out the battery, the plug, and hold down the ON button for about 30-60 seconds. Well thats how you clear it on most laptops. But if it does'nt work on the external monitor you probally have a bad video chip and need to replace your old one.
May 27, 2009 | Computers & Internet
Driver problem wiht ml3108b gateway laptop
Hi
Heres the gateway utility to automatically find and install drivers. Please rate if you find this helpful
http://support.gateway.com/support/drivers/getFile.asp?id=19318
Jan 05, 2009 | E-Machines eMachines Refurbished EMA...
Gateway laptop powers up but screen does not come up.
See if you can attach an external monitor to your laptop.If you can and you can see your display on the monitor the it is a faulty laptop screen .If you see nothing on the x monitor then the graphic card/chip is fried.
Dec 08, 2008 | Gateway M305CRV Notebook
Screen goes blank
Your Computer enters Stand-By mode when untouched for more than one hour. This appears to be NOT A PROBLEM but the SETTINGS need be adjusted. Follow these SIMPLE steps to resolve it: -
(1) Goto Control Panel>Power Options>Power Schemes,
(2) Set the System standby to Never.
(3) Click Apply.
(4) Click OK.
Your Problem finished.
SAHAJA YOGA IS THE ONLY GATEWAY TO THE KINGDOM OF GOD AND IS THE CULMIINATION OF ALL THE RELIGIONS AND SPIRITUAL TRADITIONS OF WORLD.
May 24, 2008 | Computers & Internet
Computers & Internet Logo
1,219 people viewed this question
David Payne
David Payne
