Question about Refrigerators
Whirlpool side by side
Water comes out but will not make ice. Ice maker makes ice in freezer but will not come out on door. Water does work on door.
  • 172 Answers
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Posted on Dec 02, 2008
Ice maker in Kitchenaid KSCS25FT does not refill. Makes ice cubes when filled manually. How to fix?
When an ice maker produces ice after filling with tap water and then cycles and does not refill with water that is an indication that the=> 2319734 Dual Water Inlet Valve
is defective. Replacing the water valve should get you back into the ice making business. The 2319734 Dual Water Inlet Valve has two sides. One side is for the dispenser and the other side is for the ice maker. When one side goes bad you end up having to change the complete dual valve set. Here is a link to a Whirlpool Ice Maker Trouble Shooting Manual Here is a link to another source for the 2319734 Water Control ValveI will be here should you have questions please ask, Thanks Sea Breeze
Apr 09, 2013 | Refrigerators
I've got a Whirlpool side by side refrigerator that is about 7 years old. The freezer side works, the frige side works, and the ice maker is making ice. The front door ice and water dispensor isnt working...
That will take a few test to determine which is the most likely. Most times it is a loose connection in wiring harness as it goes from cabinet to door or the freezer light switch is defective. When you open door to freezer all of the fountain and ice maker power is disconnected for safety reasons. If the switch is defective when door is shut then these are acting as a lockout. But you just said ice maker works so we are back to a bad connection or the LV (Low Voltage)board itself. This will take someone with a multi meter and follow through with me and wiring from the tech. sheet. I will try to make a wiring diagram for you to follow here. Thanks, Sea Breeze
Jan 19, 2011 | Whirlpool GD2SHGX Refrigerator
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Ice Maker stopped making ice - the unit is only 4 months old
Lets try this because I need the model nuber first befor giving the complete solution. Pour water into Ice maker tray turn on and let freeze. If Ice drops into ice bin and water does not come on the the dual water cotrol valve. If ice maker does nothing it wil be you ice maker or the grees F. See around door for model number, Thanks Sea Breeze
Apr 09, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice maker not filling with water to make ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker makes ice but doesnt kick it out
seem likes the heater on the ice maker mold is not working , you'll need to replace ice maker
Dec 15, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
