Question about Equator EZ 1500 Front Load Washer / Dryer
Dryer doesnt work in my combo washer /dryer
''my dryer stop working'' but the washer still washes nicely please send me a email to help me fix it here are the symptoms: 1.there is no heat coming from my dryer at all!! 2. i try to clean the filter at the bottom of this machine but still no heat. 3 the filter had water in it so i let it out and tryed again and again and still no heat . 4. so at this point i started the dryer at ''heat'' but that didnt worked either i got feed up ...helpppppppppppppppppppp! what do i need to do to get the dryer running again? thanks for your time Roxi baby
  • Anonymous Jul 08, 2008
    how do i wash and dry
  • Anonymous Aug 17, 2008
    No heat from dryer
  • 247 Answers
Another possibility is that a thermal cutout may have popped. Not sure how your particular machine is laid out, but the following guidance would have worked equally well for either of the washer-dryers I've had in the last fifteen years. Underneath the worktop is a large flat metal duct (which houses the dryer heater element). Onto this are screwed some (guess two or four) thermal cutouts - these are flattish round things 1 to 2 cm in diameter with a couple of lugs on to attach them to the duct and a couple of electrical connections - may look like the itme here: http://www.dabsspares.com/product.aspx?c=1085&ma=775&mt=0&mo=677696&id=488271 Look to see if any of these have a button (often just a little plastic rod) coming out the middle. If you find any of these, FIRST MAKING ABSOLUTELY SURE THE POWER IS OFF, give the button a push. If you're lucky, you'll hear a click and the cutout will be reset. A.
Posted on Feb 02, 2007
    Problem Solver:
  • 13 Answers
This will be the heater at the top of the drum open cuircuit. or the thermostat o/c. or if you can no longer hear the cuirculation fan spining , then this is your problem. appliance doctor
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Kenmore Series 70 Stopped heating up
Dryers have a thermal cut-out (TCO) that can trip in an overheat condition. Yes, it is possible to restrict air flow from clogged lint and cause this overheat condition. The TCO acts as a fuse and cannot be reset. If defective, it must be replaced. Here is a link that also explains other causes of dryer heat related failures:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Now...normally if there is heating circuit failure, such as the TCO or heating element, the dryer drum will still rotate. The dryer just does not heat. If this is not your symptom, you may have another cause to your failure. This next link, provides more detailed symptom elaboration:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention to the sections in these links that discuss proper dryer ventilation. Poor air flow is the number one cause of dryer failures and dryer fires.
What is your model number? This will determine how your dryer is configured and where the heating components are located. If you have further questions, please let me know. I hope this helps you.
Jan 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer/dryer combo
I Can give you a few things to check if your mechanically inclined, but if you dont feel comfortable digging into the machine I would suggest a technician visit..   if you feel like digging into it send me an email at bigtexan1000@yahoo.com and we can begin
May 30, 2008 | Kenmore 88752 Top Load Stacked Washer /...
GE Harmony gas dryer wont heat
post your email i will send you the servuice manual on it
May 08, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Timer, or Heating element?
The timer small motor malfunction or open./ remove test the two wires by multi tester the continuity/ no response motor broken./ test also fuse . if ok / sometime if motor pop same time fuse burn.
Jan 05, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Dryer not working
If the drum is not moving: There is something stuck inside your furness blower( could be some pice of cloth). Open the furness and remove the piece and your dryer will be working fine afterwords. If the Drum is working fine; the coil valve, fuse or the gas ignitor could be the problem; usually repacing the coil valve will fix the problem
Oct 14, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Equator EZ 1500 Front Load Washer / Dryer Logo
221 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Marvin
Marvin
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
