Accurian Flashing Protector?
After the carpet cleaners came in.
  • 979 Answers
Umm. Need quite a bit more info..
Posted on Dec 02, 2008
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
I have a accurian 5.1 ch surround stereo and when I cut it on it flashes protector and cuts off how do I fix this?
there is supply shorting problem if you have multimeter then check shorting
which component geting short replace this component and try
May 18, 2012 | Audio Players & Recorders
I have the 7350 prodry carpet cleaner and it while cleaning a room today it completely shut off with no rhyme or reason.
It has a build in clog protector. Once the machine starts to overheat due to a clog, it should shut off to prevent burn out. Unplug the unit, Make sure there are no clogs, sometimes even the smallest clog does not seem major but remove them. Also, make sure cannesters are all connected proper and tight. Good luck!
Mar 26, 2011 | Bissell 7350 PROdry Upright Steam Cleaner
How to overcome "error message" 'PROTECTOR' on Accurian 6.1 Sirius-ready surround receiver model 31-5048?
Probably need to replace output transistors and a resistor or two. Could also be one of the 12v regulators.
A job for a tech not for the average do it yourselfer.
Repair cost around $100-120
Nov 15, 2009 | Accurian AVR-5048 Receiver
How to clean seats
I ALSO HAVE A 2006 PT AND WORK FOR A CHRYSLER DEALER. THEY USED THIS MATERIAL IN PT AND JEEP AND IT IS TERRIBLE TO CLEAN. THE ONLY PRODUCT THAT WE FOUND THAT WORKS IS WOOLITE CARPET CLEANER IT IS CARRIED BY WAL-MART IN A GRAY SPRAY BOTTLE AND SAYS PET + OXYGEN ON THE LABEL. IT IS WITH CARPET CLEANERS NOT AUTO. YOU NEED A MEDIUM BRISLE BRUSH AND NEED TO DO THE COMPLETE SEAT YOU CANNOT SPOT CLEAN THESE IT MAKES IT WORSE. AFTER THERE ALL CLEAN AND DRIED GOOD ADD A COAT OF FABRIC PROTECTOR IT WILL KEEP THEM CLEAN A LITTLE LONGER
Aug 02, 2008 | 2006 Chrysler PT Cruiser
Accurian 6.1 Receiver flashing PROTECTOR
Your speakers have the wrong impedance rating. Check the Accurian specs.
Also possible you have short circuited some how... cross wire, bad speaker?
Jul 11, 2008 | Accurian AVR-5048 Receiver
Portable Accurian DVD player
This may sound overly simple but try disconnecting the power from the unit (i.e. unplug it from the wall), wait a few minutes and plug it back in, kinda like a hard re-boot.
Jan 17, 2008 | Radio Shack Accurian APD-3955
100 people viewed this question
 Grubhead
Grubhead
