Question about Sport & Outdoor - Others
Water build up in the starter & Reqoil case of my Polaris ATV
I own a 2003 Polaris Sportsman 500 H.O ATV and I recently ran into a deep water pit, not enough to flood & stall the entire engine, but enogh that I noticed in the extreme cold days (below freezing) that my starter will not turn over and my reqoil will not pull start. I would literally have to put the ATV in a warm area and wait for it to unthough, which it would then start. I would like to know where the drain plugs are so I can drain the housing units of these two area's and any others that may need it so I can start it in extreme temps.
  • 63 Answers
Your drain plugs should be visable, if they exist, on the lowest point of the body of the device. If you can't readily see them, consider drying out the entire unit with a hair dryer and a little patience in drying the entire unit. From then on, I would consider evaluating the depth of water before entering. After all, the unit may not be amphibious, which sounds like your intended use!
Also, the battery may be affected by the extreme cold, as they often are, leaving a different approach to this problem. Good Luck!
Posted on Dec 06, 2008
How do I replace a starter on a 2004 500 Polaris ATP
Search Results
Polaris Sportsman 500 ATV Starter Replacement - YouTube
? 12:50 Apr 17, 2013 - Uploaded by mossman381
Replacing the starter on the 2000 Polaris Sportsman 500. Doing some checks before to make sure the ...
Polaris 500 Sportsman Starter Replacement - YouTube
? 4:28 Aug 24, 2014 - Uploaded by Cruiser Mac
Putting a new starter on my 500 Sportsman and doing a couple of other things while I am at it.
DIY How to Replace a Polaris Sportsman ATV Starter Motor No Clutch ...
? 13:57 Jun 28, 2015 - Uploaded by Mark Jenkins
... of replacing a starter motor on a 2003 Polaris Sportsman 500 H.O. The ... Hey Mark I just got a 2004 500 ho ... replace starter on 2004 500 Polaris ATP Google Search
Jul 02, 2017 | ATVs
Just bought this bike had no manuals with it I need to know about checking and changing oil
PDF]Sportsman 400 H.O. Sportsman 500 H.O. - Polaris
... parts and acces- sories, available through our online store at Have ... 2012 SPORTSMAN 400/500 HO Owner's Manual. P/N 9923420 ...
Polaris Sportsman 500 HO Owner's Manual - ManualsLib > ... > Offroad Vehicle > Sportsman 500 H.O.
View and Download Polaris Sportsman 500 HO owner's manual online. PolarisIndustries All-Terrain Vehicles Owner's Manual. Sportsman 500 HO Offroad ...
2011 Sportsman 400/500 Service Manual - Polaris ATV Forum > ... > ATV Repair and Maintenance
Apr 11, 2011 - Indy Red 2011 Sportsman 500 H.O. -Polaris rear rack extender -Ricochet a-arm guards -Polaris fender bag -Koplin hand guards w/mirrors Owners, Service, and Parts Manuals
Sep 14, 2012
2005 Polaris 500 H.O. ATP service manual
Aug 12, 2011
Service manuals
Nov 29, 2010
Service Manual
Sep 23, 2010
More results from
Dec 21, 2015 | Polaris 2011 Sportsman 500 H.O
How to bypass kill switch on 2005 polaris sportsman 500 ho
If it is firing with starter fluid it is probably not an electrical problem as that indicates you have spark at the plug check to make sure you are getting good spark continous if so the problem is in the fuel delivery process water in carb stuck float fuel line filter plugged etc
Oct 12, 2014 | Polaris ATV
Why is fluid coming out of the weep hole on my 2003 600 twin polaris sportsman
possible it coming from you water pump
that happened to my 500 polaris ho
Jul 09, 2014 | Polaris ATV
2008 polaris sportsman 500 won't start, but relay clicks and will start when relay terminals are jumped
I have seen this on a few machines. Start tracing wires. Ground wire from the key is the first on Id check. Grounds on these machines go bad from vibration and rough terrain. Not to mention silt in the water.
Feb 16, 2013 | Polaris ATV
Polaris starter getting water in it
The o-rings on the starter do dry out and crack apart. But they are not water resistant. So check the orings on the starter and on the flywheel cover.
Jun 16, 2012 | Polaris ATV
Why does my sportsman 500 cut out when going in water
It will cut out when ever water is drawn into the air intake. Polaris may make a special kit to elevate this intake just like they do in a hummer. J.
Jun 16, 2010 | Polaris ATV
I have a 1999 sportsman 500 4x4 that has now power
i have a polaris magnum 330 4x4 with the same problem mine still does it because i havent did anything but i think ive got water in my oil but in low gear it pulls fine
Jan 09, 2010 | Polaris ATV
2007 Polaris Sportsman 500 won't start. New
1999 polaris 500 sportsman, changed battery and now front lights will not come on. Suggestions?
Oct 22, 2009 | Polaris ATV
4 wheel drive goes on and off
you ever change the hub fluid?
Jul 17, 2017 | Polaris ATV
Sport & Outdoor - Others Logo
253 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
