Question about HP Office Equipment & Supplies
I cant install the Windows disc on to my computer
  • 404 Answers
Hi! when you say Windows Disc? I presume it is genuine? If it is is then should be bootable. Place disc in drive shut p.c. down then turn back on, you will be prompted to press any key to boot from cd, let windows load files then set location/keyboard after this an install should take place depending on what O/s you are using. Make sure you have serial key written down.
Hope you are now sorted?
Paul 'W'
Onyer~EDson(:0)~[><
Posted on Dec 02, 2008
Rv510 disc controller
You may have a manufacturer recovery partion that windows installer see but it's uwriteable as it's protected. The usual partion is C:
Try again with C: as the partion, if it's not C: then look for the biggest partion, usually in Mb's.
Jul 08, 2017 | Computers & Internet
How do I reset to factory settings?
Reboot and look at the bottom left should be f5 and follow instructions good luck!
Dec 24, 2012 | Acer Aspire One D257-13404 Netbook 1.66 Gh...
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Note that on your Dual Boot system there now should be only one operating system listed.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
g) At the DOS prompt type the following three commands
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
These messages are the result of the radical changes made by removing the other drive.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
Reboot the computer.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
Acer Notebook was getting slow then i try to reset then after the process it restarted then said "Setup is starting services". It shows a error message "The computer restarted unexpectedly...
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
Aug 28, 2011 | Acer Computers & Internet
Windows Installation Disc..Toshiba Laptop
unfortunately when this happens it means your computer is suffering from a catastrophic system failure. In this case brought on by the hard reboot.
you can reorder a set of disk from www.toshiba.com. sorry it's not better news.
Sep 17, 2009 | Toshiba Satellite Pro L300 Notebook
Cant install sims 2 double deluxe.
Hi there, is the disc damaged at all? if it is, but not very deep scratches, try polishing the disc/disc's, with a very soft cloth. make sure you clean the disc from centre outworse not side to side like most people do, if there is any stains/marks on the disc, try watching them off my damp soft cloth and cleaning it gently, and then dry with enough soft cloth inwards out again.
Also go to your program files making sure there isnt any semi installed versions of Sims, if there is delete the folder for the Sims 2 Double Delux and try again :)
Also alot of games dont install with windows vista, why i am still using windows Xp, untill windows 7 comes out to the public.
Hope you found this helpfull.
Apr 10, 2009 | EA - Electronic Arts The Sims Double...
I m looking for recovery cd of my notebook TX 1301.
HP TX1301 - you should have got one with your computer or at least a utility on your computer which creates recovery discs using your own blank discs.
See this for Windows XP http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph08097
Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=&product=81351&docname=c00810334
If you are running Vista and you cant boot your computer , insert the vista installation disc into the drive , start the computer off the install disc , click repair my computer when you get the "Install Now" option to access vistas recovery tools from the disc
Jan 07, 2009 | Computers & Internet
Cant re-install windows vista to my dell vostro 1700
Did you try the repair option again, this time just choose repair. If not you need to clean install the computer. You can go the microsoft site to get full instructions for "Clean Install Vista"
Dec 09, 2007 | Microsoft Windows Vista Ultimate Edition
Ilo mp3 player issue
Your ilo should've come with a disc. That disc should install windows media for you. You can't put music onto it without windows media.
May 05, 2007 | iLO MP3 Player
Seeker5211
Seeker5211
