Question about Sharp AR-5316 Advanced Digital Imager Copier
2h flashing on screen,won't print
Help
This rise in the number of machines in the surf 2eica What can I do to solve the problem.
Posted on Jan 08, 2014
  • 8 Answers
Heat roller problem , enter # ,interupt, c , interupt machine goes off and enter 14 then press print buttom. this might clear ur problem. if it repeat same h2 code. need to change thermister and enter above code 14 again
Posted on Dec 02, 2008
What is a 2h error?
  1. Samsung washing machine 2h error code on the screen ...
    www.fixya.com/support/t6531747-samsung_washing_machine_2h_error
    Oct 23, 2010 - The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you ...
Jul 10, 2015 | Samsung Washing Machines
What batteries go in this unit how many 12? need a replacement
8.3 Battery Configurations
There are different configurations for different battery types and backup time. Here, the batteries from VISION and
YUASA are selected. The backup times ranges from 1hours to 4hours for 20KVA UPS and from 1hours to 2hours
for 30KVA UPS, because of limitation of CLA power rating.
UPS Backup
time Number of blocks Type of blocks Capacity(10H)
1h 1×24 6FM55SGX 52Ah
10kVA 2h 2×24 6FM45X 2×42Ah
4h 2×25 6FM75X 2×74.5Ah
1h 24 6FM75X 74.5Ah
15kVA 2h 3×24 6FM45X 3×42Ah
4h 3×25 6FM75X 3×74.5Ah
1h 1×25 6FM90X 90Ah
20kVA 2h 3×25 6FM55X 3×52Ah
4h 2×26 6FM150X 2×144h
1h 2×25 6FM75X 2×74.5Ah
30kVA
2h 3×24 6FM100X 3×96Ah
Sheet. 4 the battery configuration with VISION battery
UPS Backup time Number of
(10H)
1h 2X24 NPL24-12 2X24AH
10kVA 2h 2×26 NPL38-12 2×35.3AH
4h 2×26 NPL65-12 2×60.5Ah
1h 1×27 NPL65-12 60.5Ah
15kVA 2h 2×24 NPL65-12 2×60.5Ah
4h 3×26 NPL65-12 3×60.5Ah
1h 1×27 NPL100-12 92Ah
20kVA 2h 2×24 NPL100-12 2×92Ah
4h 4×26 NPL65-12 4×60.5h
1h 3X24 NPL65-12 3×60.5Ah
30kVA
Mar 30, 2014 | MGE Galaxy 3000 UPS System
My 42LD450 won't stay on! It turns on for a few seconds and works fine, then the screen flashes then comes back on, then flashes again after a couple seconds, then turns off. Rinse and repeat. Tried...
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
Jul 10, 2011 | LG 42LD450 42 in TV
The address of sony ericson agent atKowloon
Here's the address and phone #
Kowloon 20/F, Ginza Plaza, 2A-2H Sai Yeung Choi Street, Mongkok Tel: 8203 8863 Monday to Saturday: 11:00 - 20:00 Sunday & Public Holiday: 12:00 - 16:00
Tel: 8203 8863
Hope this helps!
Please Rate:)
Gary
May 18, 2011 | Sony Ericsson P1i
Stays on 2H when turning on
Hi welcome to Fixya. You're right what you're describing is not delay start, but rather a problem with one of the heating component's and most likely the heater relay on the electronic control. The wash cycle has exceeded two hours without a temperature increase of the water and therefore the control "thinks" something is wrong. Whether there is or isn't remains to be seen. Likely if you let the unit operate from that point of displaying "2H" it will run and run for several hours and not heat the water. You can confirm this by pulling out the control and visually inspecting the printed circuit side of the control. Look for a burnt solder on the opposite side of the largest relay ( black or orange retangular box ). That will confirm the heater relay is faulty and the control either needs to be replaced or repaired if you are capable of resoldering the board. Let me know what you find and I'll try and assist you further if you require any. Thanks for visiting "fixya" today and good luck moving forward. macmarkus :)
Jun 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
1999 Mitsuishi Montero sport 2H shift light flashing
Bad 4wd position sensor located on transfer case or bad sensor located on right front axle housing for 4wd engagement position.
Mar 29, 2009 | 1999 Mitsubishi Montero Sport
Mitsubishi delicia 2.6 td (shogun engine). fails to release from 4wd so two front wheel lights flashing on dash. Its an auto but have tried usual things like re-engage then disengage and straight line...
Check the super select solenoids. I had the same problem with my pajero/montero io, when I released 4WD from 4H to 2H the two front wheels lights started flashing. They stopped flashing and was solid on when I re-engaged the 4WD (2H to 4H).
My problem was a failure in the 2H solenoid, it was not producing enough vacuum. The problem was intermitent at the begining and then was permanent.
I checked the solenoids in this way:
1) The solenoid that receives the vacuum in the botton is for 2H
2) The solenoid that receives the vacuum in the top is for 4H
3) Both solenoids operate in the same way, they only change in the way they transfering vacuum from top/botton to the exit pipe (2H or 4H). The difference is that one has the vacuum input on the top and the another one in the botton.
4) The default position when you disconnect the electronics is 4WD
5) Try disconnecting the electronics and switching the output pipe between the solenoids. This will put the solenoids on 4WD position and you changed the pipes, so the 4WD should disengage.
4WD should disengage if your 4H solenoid is OK, the ligths should now flash when you change from 2H to 4H because 4WD cannot engage because the pipes are switched. You can also check the vacuum of each solenoid with your finger on each one.
If this doesn't work, try to bypass the solenoids and connect the input vacuum hose to the 2H output pipe. If the lights doesn't turn off in 2H mode it's posible that you have different problem.
Also check this address: http://4wd.blogeasy.com/article.view.run?articleID=318776
Good luck.
Jul 25, 2008 | Mitsubishi Pickup Cars & Trucks
Sharp AR-5316 Advanced Digital Imager Copier Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
