Hitachi 46W500 loses video after 10 seconds when connected to motorola HDPVR using HDMI/DVI cable. Works with Yb Yr...ideas?
  • 107 Answers
Check your setup in HDPVR lower resolution to 720P or 1080I or check HDMI cable adaptor or set your Hitachi on auto detection video in MENU
Good luck
Posted on Dec 02, 2008
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
Jun 14, 2016 | Hitachi Televison & Video
Says my hdmi ports are unsupported. they worked yesterday but now it wont work on the dvd player, xbox 360, or the ps3. got any idea of how to fix this or how i can reset the tv?
Hay there i have the same problem and found out my LCD does not support xbox360 via hdmi have to use a componets cable not the standard av cable its the ones that go in to the YB,YR,PR slots like an RCA but they are actualy HD quality cables that will give same affect as using the HDMI cable and its hlf the price to!!. With the use of the components cable you will be able to veiw xbox360 in full hd up to 1080i or 1080p hope this helps as there many unanswered questions here! Who the hell runs this site? They arent very helpfull ay!!!!!!!!!!!!!!! Regards Matt Rocket
Oct 16, 2010 | Hitachi Televison & Video
I have a 51UWX20B TV. I want to get a Blu-Ray DVD
Yes there are a few options for you to make the link between your TV and the BluRay DVD player, first there are adapter cables made with HDMI plug on one end and DVI plug on the other end, remember that with this cable you will have to link the audio signal with another cable because DVI only passes video. Second if you cannot find the adapter cable in your area you also can use the component video(red,blue,green)instead of the other adapter cable,that is if your TV has component video ports, and again audio will have to be linked with another cable because component video only passes video signal. Good luck !
Nov 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Is it hd
Strictly speaking to be HD Ready a TV must fullfill 2 things:
1. Have a Screen Resolution of at least 1024 x 768.
2. Have at least 1 HDMI Socket.
Your TV has neither of these, so it is NOT HD Ready, however, it will still be more than capable of showing SKY HD, and it will still look very nice indeed.
I would need a list of the connections on the rear of the TV to tell you which cable to buy, but:
If it has DVI, then a simple HDMI to DVI cable will do for the video.
If it has component, i.e Yb, Yr etc then you will need a more expensive HDMI - Component Video cable.
But otherwise, yes, SKY HD will work fine.
I hope this helps.
Mar 28, 2009 | Televison & Video
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
