Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Need cable I want to plug the output of a Digital comverter box into the TV to get true 1080i. The PFM-42B1 Plazma does not have component in. Just two 25pin picture inputs.
  • 3 Answers
You need a hdmi cord
Posted on Dec 02, 2008
Need a cable to hook tv to dish network box
Use and HDMI cable if your tv supports it. This Cable is convienent and will provide the best audio and video quality. They range greatly in price. You can get a good $20 cable at any major retailer.
Aug 11, 2011 | Sony PFM-42B1 42 in. HD-Ready Plasma...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a sony pfm-42b1 plasma tv with 2 vga inputs an 1svideo input.. i want to connect my ps3 hdmi cable to the vga input. i purchased the cable but nothing shows.. thanks for your help
you should change it from hdmi to cable. You can do it only on a hdmi tv when you do that you can use it for the pfm-42b1e because i had the same problem too. when you plug your ps3 to a hdmi tv you go to settings-display settings- video output settings than you change it to av multi. After you do that you can use it on pfm-42b1e
Dec 16, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
Ws-65313
this is correct! this tv does not have the ATSC tuner built in. 1080i is a format of the digital broadcast approved by the ATSC. you must have a source of this format to veiw this format. standard cable boxes and satilite boxes altho digital are not outputing HD formats so you need to have the HD boxes to veiw HD 1080i and the broadcasters must be broadcasting HD to get true HD.
Sep 03, 2008 | Mitsubishi WS-65313 65" Rear Projection...
PFM 42B1 [HELP]
Count the flashes - This is an error code - Usually between 1 and 6 flashes followed by a pause.
Aug 30, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-42B1E plazma screen
Does the red standby light flash ?? If so count the flashes and see my error code section.
Jul 05, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Need PDP (PFM-42B1) vertical ribbons-drivers replacement (rebonding)
vik_ny
Your best bet, if you have ther board out yourself is PTS Electronics. Techs even feed these guys because they're well known for their quality of work and reasonable price. If you're looking to have a shop there bring the whole set in and work on it maybe this will help.
http://www.nesda.com/locator/state_search.php
Good Luck!
Bill
Nov 25, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Dark Shaded Rectangle in the middle
Check the settings for the input and make sure captioning is not on....text mode does this on mine, figured it out after hours of pulling hair out...
Oct 17, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
130 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
