Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Dishwasher wont drain water
My dishwasher has standing water in the bottom
  • Anonymous Jan 01, 2009
    The water is not draining....this sucks!
    Novelist:
  • 166 Answers
Hello there,
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
do not forget to rate the solution,
thanks for using FixYa
Posted on Feb 11, 2009
Model 991-9584991 f2 code keeps coming on.
If this is the he washer, you have a drain issue. Remove bottom plate. You should see a round dial, this is the trap. Remove and clean out the stuff... Water will drain on the floor, so watch out..
Nov 08, 2015 | Kenmore Ovens
How do i stop water ciming out of the freezer
check your condensation defrost run off line for blockage. may have to remove the back interior panel of the freezer to access the water catch pan. debris blocking the drain or the defrost line will cause overflow into fridge interior
Jul 03, 2014 | Frigidaire Ovens
I have a May Tag dishwasher and I am very unhappy. I use Jet Dry and a small amount of Cascade and my glasses get a white film on them. They look terrible. What can I do? Susan Ferrin
Perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 13, 2011 | GE Built-In Dishwashera Oven
Dishwasher won't empty water after wash finished
Most likely the pump that pumps out the water is bad. You may also check that the drain hose is not plugged between the dishwasher and the garbage disposal.
Mar 20, 2011 | GE Built-In Dishwashera Oven
Water is pouring out of the bottom of Rational oven SCC 101 E
theres a chance you have a deffective solenoid staying open causing the water to overfill the boiler tank and passing out the overflow into the quench box and down the drain!
Mar 11, 2010 | Ovens
Whirlpool dishwasher not pumpimg water out at the end of the rinse. Now wont fire up properly again, programme goes to start then alarm beeps and light flashes. Hose doesnt seem blocked, not sure how to...
need model # to help . but you might clean ou the sump/ and bottom sreeens this will improve water flow and ck the disposal hook up for pinch hose ..mm
Dec 07, 2009 | Ovens
The water fills and drain from the bottom of the washing machine. Have checked all the pipes no problem. Please advice
front load or top ? drain hose must be elevated to 36 '' 34 min. if hose on floor it will not work .. needs stand pipe . if its leaking inside you may have a hose off . reinstall and wala it works .. mm hope some of ans work for you ..
Dec 03, 2009 | Ovens
Maytag Model MTB2154ARW-water is appearing inside on the bottom of the refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 17, 2009 | Maytag CWE5800A Electric Double Oven
Hi have an electric Kenmore oven - did self cleaning and it started beeping with an F3 code
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 26, 2009 | Kenmore 30169 Electric Single Oven
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
137 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
