Question about Crosley CE35100AA Electric Kitchen Range
Bottom burner in oven dose not work but top burner work why
    President:
  • Crosley Master
  • 2,651 Answers
Possible hat the bottom elemnt has burnt out/broken/shorted. you would need to check the element for continuity witha power meter ifits not an obvius break.. BEWARE ALWAYS LIVE WIRELEADING TO THE BAKE ELEMNT TURN OFF POWER FIRST!!!!!!!
Posted on Dec 02, 2008
5 Suggested Answers
  • 172 Answers
SOURCE: get F5 error code. Burners
Hi jdaleq,
The f-5 code on the frigidaire ranges is a bad one. It is a ERC (electronic range control) failure. The repair manuals state to replace the control when the f-5 code shows up. You can also try to reset the control. To do this flip the breaker to kill the power, wait about 20 minutes then turn the power back on. If the problem returns then you will need a new ERC. The part number is.
#316418704 The price is $194.99 including shipping in the US. I do have these available to ship today. I hope this helps and please rate me when you can.
Mike
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
SOURCE: top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Posted on Dec 13, 2008
  • 29 Answers
SOURCE: oven burner won't light
You likely have a bad ignitor. It's like a mini element that heats up and then ignites the gas once the valve releases it. When the ignitor gets old it doesn't glow bight enough or draw enough amperage so the gas valve won't open. If you set bake and see a glow coming from under the plate in the oven but the burner never lights that's your culprit. They probably cost about $50-$80. Good luck!
Posted on Apr 28, 2009
heatman101
  • 43501 Answers
SOURCE: top oven not heating up on BAKE, broiler gas and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jan 09, 2011
Cannot get oven to work
I need more info, dose the top buners work ? dose the broiler work ? Did you take a flashlight ad look over the lower cal-rod or element ? for damage get back to me on and off here all day and some nights till 9 pm
Dec 13, 2011 | Ovens
Ge electric oven will not turn on
Hi Shane I need a little more info , like dose the broiler work ? dose the burners work , most times if the lower element isent working it has burn out , this is a cheep easy fix, look at the element with a flash light for damage it will have bump's on it or could be broken right off , this is the first thing to check , If it is the element I can locate you one to order and tell you how to change it but i will need the model and serial number and also is it the top or the bottom element , get back to me, and please always remember to rate this question: thanks Frank
Its cuts electricity off
I need more inforamation , dose the top burners work, dose any of the oven work top or bottom , Make model, serial number if you can find it
Dec 07, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
My bottom burner dose not come on.
heatman101
Aug 06, 2011 | Ovens
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Hello, The wire going to the bake element could be burned in two. Pull the range out and take the back off ( make sure you unplug it)., check the wire going to the bake element for any shorted, burned, or broken spots. The wire will lead all the way to the thermostat on the control panel. If the wire is good, you have a bad thermostat. The thermostat part number is.
part # 74005019 price $98.97
This part is listed as NO LONGER AVAILABLE at the manufacturer so you should really get one as fast as you can, or it will be gone for good. I hope this will help.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Crosley CE35100AA Electric Kitchen Range
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
130 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
