Question about Crosley CE35100AA Electric Kitchen Range
Bottom burner in oven dose not work but top burner work why
Change the burner still dont work top burner light right up when turn on but not the botton do you know why
  • 172 Answers
Hello, The wire going to the bake element could be burned in two. Pull the range out and take the back off ( make sure you unplug it)., check the wire going to the bake element for any shorted, burned, or broken spots. The wire will lead all the way to the thermostat on the control panel. If the wire is good, you have a bad thermostat. The thermostat part number is.
part # 74005019 price $98.97
This part is listed as NO LONGER AVAILABLE at the manufacturer so you should really get one as fast as you can, or it will be gone for good. I hope this will help.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
Cannot get oven to work
I need more info, dose the top buners work ? dose the broiler work ? Did you take a flashlight ad look over the lower cal-rod or element ? for damage get back to me on and off here all day and some nights till 9 pm
Dec 13, 2011 | Ovens
Ge electric oven will not turn on
Hi Shane I need a little more info , like dose the broiler work ? dose the burners work , most times if the lower element isent working it has burn out , this is a cheep easy fix, look at the element with a flash light for damage it will have bump's on it or could be broken right off , this is the first thing to check , If it is the element I can locate you one to order and tell you how to change it but i will need the model and serial number and also is it the top or the bottom element , get back to me, and please always remember to rate this question: thanks Frank
Its cuts electricity off
I need more inforamation , dose the top burners work, dose any of the oven work top or bottom , Make model, serial number if you can find it
Dec 07, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
My bottom burner dose not come on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
Hello, the top burners works but the oven does not light up. Only the red light in the bottom is on but it's not flaming. I've tried turning it off and on again but the flame still doesn't light...
heatman101
Nov 10, 2010 | Ovens
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Front right 8'' surface burner dose not light up period.
it could be your burner but most likely your infinite switch for that burner
Mar 21, 2009 | Kitchen Ranges
possible hat the bottom elemnt has burnt out/broken/shorted. you would need to check the element for continuity witha power meter ifits not an obvius break.. BEWARE ALWAYS LIVE WIRELEADING TO THE BAKE ELEMNT TURN OFF POWER FIRST!!!!!!!
Dec 02, 2008 | Crosley CE35100AA Electric Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
209 people viewed this question
Top Crosley Kitchen Ranges Experts
Rob
Rob
Level 1 Expert
Bruce Bracey
Bruce Bracey
Mike
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
