Question about Braun Activator 8595 Electric Shaver
BRAUN 8595 screen indicates i should change my foil and block
I just changed my foil and cutter and now the screen on the outside of the unit is telling me to replace foil+ cutter part no. 8000
  • Anonymous Dec 31, 2008
    My shaver just did this as well. I changed it but it is not disappearing from the screen. Let me know if you find a solution.
  • Anonymous Mar 20, 2014
    Cannot find a local repairer
There is a reset button directly underneath the LCD screen
Posted on Jan 17, 2009
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 31 Answers
Braun series 5 combi 51S screen foil and cutter block for braun 8595 blades replacement parts.
BRAUN 8595 screen indicates i should change my foi - 0a4039b4-1466-4fd3-af33-0de81be3b963.jpg
Posted on May 23, 2013
Braun 8595 screen does not work. Where can I get a replacement? and can I replace it myself?
You say 'it does not work. You mean it doesn't shave well, or not work at all. If it doesn't work at all, you need to send it for repair to the local authorised dealer where you live.
If it is just the LCD screen, you will need to have it serviced. The problem is getting into them. You need to remove the correct hidden screws and press the case in just the right places using a tool called a 'budger'.
The foil and cutter block come as a kit and are very easy to replace. Remove the foil and pull off the cutter block. Replace with new. The problem is going to be getting one though. I get mine from Amazon for my 7 Series. Although
I live in Canada, they come from Ireland in 7 days.
Let me know if you need any further help by clicking COMMENT under my name.
braun 8595 replacement foil and cutter Google Search
Repairs
Braun 8595 repairs Google Search
Jul 30, 2017 | Braun Health & Beauty
I have had a Braun 8985 electric shaver for 4 years now. I have recently replaced the cutter block and foil but I am still having a problem with the shaver. It is not unusual for me to have to make 3 or...
The symptoms you describe indicate that the 'drive unit' is the problem. This part includes the swivel frame that the foils and cutters fit onto as well as the motor. Sometimes a piece of the plastic oscillator inside will break. The vibration causes the loud noise and it can not oscillate properly because of the break.
You will find the part needed at shaveroutlet.com. See link below for this part and scroll down the screen for helpful installation video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Jul 27, 2011 | Braun 8585 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
Can i get replasment foil and head
braun series 3 combi 30B screen foil and cutter block for braun 4775 blades replacement parts.
Jan 21, 2010 | Braun 4775 Electric Shaver
New foil required for braun 370 travel shaver
Hello MrandMrsInger! You can purchase a new replacement foil for your Braun 370 at the link I've provided below. Basically, you'll be getting a new cutter block and foil for it, as the foils are no longer provided separately.
Braun, now owned by Gillette, discovered that many folks would buy just the new screen (foil) and it would get torn/damaged by a nick in the cutter block blades, so they packaged these wear items as a set to eliminate those very common problems. I had it happen to mine several years ago, so I know why they made the change.
Anyway, here's the website with your replacement parts:
http://www.electricshaverstore.com/get_list_125.htm
Just scroll down to the 2nd item shown, I believe, and you'll see your replacement set.
You can also use the part numbers to try to locate another supplier, if you wish, as these are the actual Braun part numbers provided.
Hope you find this Very Helpful and best regards!
Oct 22, 2009 | Braun Health & Beauty
When should you change cutters &/or head?
braun series 5 combi 51S replacement screen foil and cutter block for braun 8985 replacement parts.
Jul 19, 2009 | Braun 360° Complete 8985 Electric Shaver
My shaver is approximately 3years old and it "bites" me. What do you think it needs? and where can I get help in the Central Coast of California.Thank you.
HI. Have you ever changed the foil or cutter? You'll find a world of difference when you change them. It's recommend you change them every 18 months (as specified on the packet).
Your model is the Syncro which takes a 30B/Series 3 - 7000/4000 Series foil/cutter. You should be able to locate by doing a Google search.
Otherwise try http://www.braun.com/us/consumer-service.html?country=United+States+of+America&continent=am&action=country
Apr 18, 2009 | Braun 7528 Syncro System Automatic...
Braun Activator 8595 Electric Shaver Logo
630 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
