Question about LG WM-2277HW Front Load Washer
Lg wm2277hw agitator problems - LG WM-2277HW Front Load Washer
  • 32 Answers
This unit doesn't have an agitator, that could be the start.
Posted on Dec 23, 2008
I have a LG front load washer model #59WD1653 LG WM2277HW I keep getting an error message of LE I have misplaced my Manuel. What does that mean
Google is not your friend, but can still be helpful.
https://www.manualslib.com/manual/409239/Lg-Wm2277hw.html
May 30, 2017 | LG Washing Machines
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Replace door gasket lg wm2277hw
Hiya,
you can find spares for this machine on espares i think the gasket will be a universal one but here is a link for you to check
http://www.espares.co.uk/parts/lg/p/0/81?k=wm2277hw+door+gasket
Please note i have not used this site before but i have noticed that they will deliver to most countrys & im sure they will be able to help with a fitting tool issue if you contact them.
Hope this helps
Apr 20, 2010 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
I have an LG WM2277HW that shows a ''DE'' problem code
Not fully drained within 10 minutes. check the pump for strings or small items . Check drain DE=drain error.
For a manual go HERE
Nov 06, 2009 | LG Washing Machines
I have a lg wm2277hw agitator problem
I had this happen on mine, and it was the valve that dispenses the water into the drum. I wasn't getting any water into the drum because the dispensing valve/solenoid was not working. I've had to replace it 3 times in the past 5 years though.
Dec 02, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
73 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
