Question about LG WM-2277HW Front Load Washer
I have a lg wm2277hw agitator problem
The machine comes on and agitates for a second and then humms
    Problem Solver:
  • 5 Answers
I had this happen on mine, and it was the valve that dispenses the water into the drum. I wasn't getting any water into the drum because the dispensing valve/solenoid was not working. I've had to replace it 3 times in the past 5 years though.
Posted on Sep 17, 2010
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
Washing machine filled but wont agitate after the fill,it humms
Maybe the agitator isnt agitated enough.....yell at it for a bit...see what happens....if it that dont make it spin poor a lil rum in the tub....
Mar 01, 2010 | Whirlpool Washing Machines
Agitator humms and won't move
It hums since the motor is still working. However the mechanism for the agitation is not working due to the helix part worn out. Need to replace it. If the service man is coming, have him to check the spinning mechanism also, since the same labor for the 2 mechanism. if the agitation mechanism worn out then the spinning mechanism is going to wear out soon. Now keep in mind that the clutch and the brake for the spinning mechanism are hardly worn out, only the part pushing up to release the brake is worn out. Keep this in mind to prevent overcharged.
Jan 09, 2010 | Dryers
Motor just humm's when put on spin. Doen's seen to
Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of major sub-components will come up.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) or spinning the solution points to a couple of places.
1. The motor coupler may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
Remove the cabinet and inspect the coupler. Following is a good description of how to replace it if necessary.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The coupler consists of three pieces. Two plastic pieces with three prongs each that fit on the shafts of the motor and transmission and a rubber piece with six holes that the plastic prongs fit into.
If the prongs are broken off, or the rubber piece is broken, the motor cannot apply power to the transmission for agitating or spinning.
If the coupler is OK, the problem points to the motor or transmission.
If you move the timer to the spin cycle, and the machine drains the water , the motor is probably OK.
I'd also check the Lid Switch that prevents the motor from turning in the spin cycle.
Following is a Whirlpool PDf on how top load, direct drive washers work with a troubleshooting guide and description of how to bypass the LID Switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 02, 2009 | Kenmore Washing Machines
WASHER HUMMS BUT DOESN'T AGITATE
this sound i think come from motor so since there is no rotation the belt need to fit again or replaced by agood one,
g b y
Jul 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not fill with water. only agitates. will drain and will not spin only humms
unit should not agitate with no water. pressure switch has to be satisfied to begin wash cycle. what kind of washer?
Jun 21, 2009 | Washing Machines
Lg wm2277hw agitator problems
This unit doesn't have an agitator, that could be the start.
Dec 02, 2008 | LG WM-2277HW Front Load Washer
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
