Question about RCA CC6263 Camcorder
E02 Unit Insafe Guard Mode Error
When I tried to use my RCA CC6263 Camcorder I get this error on the screen. E02 Unit In Safe Guard Mode Remove Reattach Battery. I remove the fully charged battery wait 10 minutes and reinstall the battery. I get the same E02 Error. I then removed the battery wait 30 minutes and install a different fully charged batery. Still get the same E02 error. I never had any problems or errors on this camcorder before. Any Suggestions.
  • 1 more comment
  • daalorenz Nov 03, 2008
    I also have the same problem with my RCA CC6364 camera. I hadn't used it in a while, got it out, charged it up and get the "In Safeguard Mode" message. It will record and or play for about 5 seconds, then it stops and the message comes on.
  • joel123 Jan 09, 2009
    e02 safegaurd mode on my RCA cc6263 and help?
  • Anonymous Feb 27, 2009
    same as stated above error code E02 on model CC6383 RCA Serial no. 021410597
2 Suggested Answers
SOURCE:
57 varieties
  • 1653 Answers
SOURCE: E03 safegaurd mode remove and replace battery? how
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC’s and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
Posted on Oct 06, 2009
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
I have a RCA cc6364, had it for years. I bought a new battery years ago and it won't hold a charge, when the battery is on it says Remove and Retach Batterys; unit in safeguard mode. I don't know if I need...
Does your camera work of a Power Adapter? If it does, then the battery is most likely at fault. If however it will not, then it will be the camera.
Feb 22, 2010 | RCA CC6263 Camcorder
I keep getting the E02 message in safeguard mode, what can I do?
Dec 25, 2008 | RCA CC6263 Camcorder
Error message 06 appearing, I can't clear this eero, please help.
remove the battery for some 1 day and then try .. if you have connected the dc plug into the jack remove that also ....
Feb 11, 2008 | JVC Cybercam GR-D30 Mini DV Digital...
JVC GR-AXM17U
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the unloading direction for 4 seconds
or more. This error is defined as [E02].
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shif
Dec 13, 2007 | JVC GR-AXM17U Camcorder
Safe guard mode, E04
After reading some posts elsewhere, I had one thing work. If you thump the camera on the side outside of the tape itself, it will stop the error message. There is the chance that doing this too many times will render it useless, but for a quick fix I found it worked.
Good Luck
Nov 06, 2007 | RCA CC9370 Mini DV Digital Camcorder
Camcorder stuck in E02 Safemode
hey have the same problem with my camcorder too far the past 3yrs send it to jvc they said no problem found but as soon i got it back it work for one day them went back to safe mode.they said they could rplace the head mechanicalism for $350 which is roughly what paid for the camcorder.if gotyours fix let me now
Jul 15, 2007 | JVC GR-SXM260E Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
RCA CC6263 Camcorder Logo
110 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
