Question about GE Spacemaker JVM1640SJ Microwave Oven
Mircowave will not heat
GE spacemaker XL1800 Mircowave will not heat, Everything else works, Turntable, lights, vent, timer, all but the heating.is ther an internal breaker or fuse that can go bad?
  • 5 more comments
  • jzambori Dec 02, 2008
    I have a GE Spacemaker Microwave oven. Everything on the oven control panel seems to be working, but the oven does not heat up anything. After turning it on for 30 seconds or so, it also has been emitting a smell similar to plastic burning. Any solution?
  • Anonymous Dec 09, 2008
    Everything seems working, but no heat
  • jbusboom Jan 02, 2009
    I have the same problem. Everything works on the microwave except no heat. A solution that is currently working for me is to first manually turn on the vent fan. When the vent fan is running, the food heats up normally. There must be a sensor or something that's bad. I wish I knew how to diagnose what to replace b/c it's prbably simple once you know what to do.
  • Anonymous Jan 03, 2009
    I have the same problem. Everything works on the microwave except no heat. Plus humming noise.
  • Anonymous Jan 04, 2009
    Just happened last night (1/2/09). Everything works except things to not heat up. The unit is from 2000. Is it worth repairing?
  • offroadindad Jan 06, 2009
    I have the same problem as the above. Buzzing noise, plastic smell, no heat. I would like to fix it if posible but need to know how to test the components that may be causing this. Any thoughts?
  • Anonymous Mar 12, 2014
    Light comes on turntable functions but it will not heat
  • GE Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
My ge microwave spacemaker profile model # JVM1860BF001 stopped while in use. Interior light, clock and timer work. Door vent opens. turntable doesn't work. Won't heat.
check the breaker, or check if the wall socket works. If there is power, then you need to take it for service. There are no user service options for microwaves as they are so dangerous for both super high voltage and also microwave emission. Some models do have a pull fuse on the rear, so check for that first.
Oct 04, 2016 | GE Microwave Ovens
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Profile Spacemaker XL1800 is not heating my food all of a sudden. Everything else like turntable, electonic display, fan, timer etc. all seems to work as normal. What do you think is wrong?
This could be as simple as a loose high voltage connection or somthing more serious, I would suggest asking a qualified technician for a quote to repair.
Jan 07, 2010 | Microwave Ovens
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 (jvm1850sh06) problem
Use a hair blow dryer to dry out the underside of the microwave. After you are convinced that it is dry you may operate it again.
That said, if it still is acting up read this:
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Aug 06, 2009 | Microwave Ovens
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
No turntable, no heat. Light, vent fan and keypad all work...
That would be a problem with your primary interlock switch or its mount.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The interlocks are highlighted in the diagram below.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 28, 2008 | GE XL1800 1100 Watts Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
180 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
