Question about Marantz SR-7200 Receiver
Marantz SR 7200
Dear all, When I switch on my Marantz SR 7200 A/v receiver, it comes on and then immediately switches itself back to standby. Please tell me what to do...This thing cost alot of money and I feel cheated that I should lose it just like that. Sincerely Gladys
  • john1959 Apr 14, 2008
    i have a Marantz SR 7200, It shuts off after 9 minutes after turning it on.
    the standby red light remains on. I have tried removing all connections to see if it would eliminate this problem, this shut off. I have even pluged thr sr7200 into a different outlet in another room, i dont think the house wiring
    is at fault. Any ideas?
  • kndyapl Mar 20, 2009
    I turn the amp on and it goes on for approximately 4 sec. and then switches to standby. It smelled like plastic for awhile there.
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Posted on Mar 29, 2009
Possible Solution:
Your speaker cable end points are touching causing the amp to switch off to prevent short circuit.
Posted on Mar 20, 2009
  • kosta_75 Mar 20, 2009
    You may have speaker cables connected from the amp that are not connecting to a speaker and they may be touching. This may cause the amp to shut down.
    Novelist:
    Champion:
  • 219 Answers
Sounds like it is zapped (fried outputs). Time for a trip to the repair shop. Good luck.
Posted on Jan 29, 2007
    Problem Solver:
  • 6 Answers
We have marantz servicenter in New Delhi okhla phase-1,Show room in Khan market. for more details call +91 9871371720
Posted on Aug 25, 2009
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
The receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
Dec 29, 2009 | Marantz SR-7200 Receiver
OSD control from receiver
I had the same problem on my 7200 until I realized that the display comes up on the television screen. I carefully followed the set up required from the manual. I got the Manual online at Marantz.com. I have a cable hook up so I connected the video cable out from the box to the Video in source on the 7200 and monitor out to my Television. I then pressed the Amp button to get the remote to Amp mode. I then pressed the OK button that is in the center of the four direction buttons and the menu displayed itself on the screen . I hope this helps. ercble
Nov 28, 2008 | Marantz SR-7200 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Oct 02, 2008 | Marantz SR-7200 Receiver
Marantz SR 7200
Most often it is due to improper speaker loading. In other words, it needs to have from 4 to 8 ohms speaker load and you wired your speakers in parallel when they should have been wired in series. What would have been an 8 ohm speaker load in series, turns into a 2 ohm load when in parallel. And with dual voice coil speakers you just compound the problem. And don't even get me started on bridged outputs.
Anyway that is what usually causes an amp to fry. Good luck.
Aug 03, 2008 | Marantz SR-7000 Receiver
Marantz sr-7200 no OSD
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Jul 24, 2008 | Marantz SR-7200 Receiver
Marantz SR 7200 Receiver
DSP (Digital Signal Processing) Board is probably defective or has Poor solder Connection on one of the Ic's on that board. Board cannot be Obtained from Marantz. Must be troubleshot at component Level and requires a very knowledgable tech to repair it. I have done a few of these in the past and usually charge $50 to Evaluate and Give estimate. kstahl65@att.net
Dec 26, 2007 | Marantz SR-7200 Receiver
Marantz SR-7200 Receiver Logo
1,222 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
