Question about Electrolux Guardian Bagged Canister Vacuum
Electrolux Guardian canister electrical problem
At first the red light lit up and vacuum would not switch on. Trying to figure out where the short was I tried using a test light where the plug of the hose plugs in and I think I burn't out something else because now the red light doesn't come on. Any ideas on what to test. I have a digital multi meter but am not shure where to start.
Thank you for your time.
    Scholar:
  • 44 Answers
I believe there is a fused lead inside of the canister. Depending on where you connected your test light, you may have blown this fuse. I don't think you will have much luck finding aftermarket parts for this unit, so you may want to find an Aerus dealer. You can go to Aerusonline.com and use the dealer locater to find the closest store. Good Luck!
Posted on Jan 02, 2009
Where is the reset button on my electrolux guardian canister
There is a reset button on the power nozzle...not sure I heard of the vacuum canister has a reset button....hum.
Feb 15, 2013 | Electrolux Guardian Bagged Canister Vacuum
Electrolux canister C104A: Unit shuts itself off and LED in handle next to OFF button flashes.
I have a similiar problem, but LED light does not flash. I have determined it is a short in the hose wire. THERE ARE NO REPLACEMENT PARTS FOR THIS MODEL OF ELECTROLUX. I'll never buy another Electrolux product.
Oct 31, 2010 | Electrolux Guardian Bagged Canister Vacuum
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Broke cord reel on Lux Ren.
The only way is to replace the cord winder assembly.
Feb 20, 2010 | Electrolux Guardian Bagged Canister Vacuum
Don't know where to turn on the vacuum of the electrolux guardian. Bought it used. Can you help?
Usually these types of vacuums havve a foot operated switch that is part of the body and kind of blends in with the body of the vacuum, they may also have a switch on the handle.
Feb 03, 2010 | Electrolux Guardian Bagged Canister Vacuum
Put in new bag but as soon as we turn vacuum on motor stops red light comes(bag full)
make sure the bag is installed properly and the bag door is making contact with the small switch by the bag.
Jan 03, 2010 | Electrolux Guardian Bagged Canister Vacuum
ELECTROLUX C101H JUST SHUT OFFWHILE WIFE WAS VACUUMING, DOES THIS HAVE AN INTERNAL THERMAL OVERLOAD SWITCH ? HOW TO OPEN UP CANISTER TO SERVICE ??
it does have an internal thermal overload device you need to put the vacuum into the shop they should be able to fix it in a few days
Aug 01, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Twenty year old Electrolux canister swith stopped working
What switch? If the switch is inside the tank, open it from the underside with 3 screws.
Nov 30, 2007 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
120 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
