Question about TruTech PLV16320 Television
When pressing the numbers on the remote the channels are not changing to the right channels
    President:
  • 814 Answers
You can try to change the batteries and if this does not work, try turning off you television and unplugging it for a couple of hours. Also take the batteries out of the remote and let it set for the same amount of time. Then try reusing them as normal and see if this solves you problem. If all this does not help you , you can call these numbers for technical assistance. 1-888-252-6252 and 1-800-252-6252. I hope this helps you with your problem.
Posted on May 17, 2009
    Genius:
  • 1,199 Answers
TRY BUYING A CHEAP UNIVERSAL REMOTE! I THINK ITS YOUR REMOTE
Posted on Dec 07, 2008
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
I have a T4053H Samsung HDTV I bought Jan. 2008. My tv is hooked right to cable tv service with no boxes in between. When I press in the numbers it can take up to 6 seconds for the channel to change. The...
It is a fault in the control board or in the remote, try first testing with an universal remote, If it works with Un.Remote change remote, otherwise call repairman
Apr 29, 2008 | Televison & Video
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Dec 31, 2011 | Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Problems with getting channels locked in on our plasma tv
Yuo can change the pin # even if you don't know the old one then you can can turn off with the new one.
Press the 'MENU' button on the remote control.
Press cursor down to select SETTINGS.
Press cursor right twice.
Press cursor down to select MENU PREFERENCES.
Press cursor right.
Press cursor down to select CHANGE PIN.
Press cursor right once.
Enter code 0711 if you have don't know yours
Enter a new four digit PIN using number buttons. Number combinations from 0000 to 9999 are valid.
When prompted to confirm PIN, enter new PIN again.
Press the 'MENU' button to exit the menu.
Feb 22, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Can't change channels.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
you can also buy a universal remote and it might help you. keep in mind, the remotes don't always have the right buttons labeled, so sometimes you have to try all of them first before finding the right button to bring up the setup menu.
Jan 20, 2009 | Sony RMT-V501E Remote Control
Box super starview
has any one got any information for putting codes in starview 3 super
thanks 817440.
Nov 05, 2008 | StarTech.com StarView SV211K 2-port KVM...
TruTech PLV16320 Television Logo
24 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
