Question about E-Machines D4362 (RBD4362) PC Desktop
Memory for the D4362
This is really frustrating. Even on here it shows this computer as having two memory slots. My D4362 has four. I've gone to different memory sales site and I've found I can add up to 2GB or 4GB. That it can take up to PC3200 ram or only 2700 is guaranteed to work. Is anyone running 4G of memory in one of these and what speeds seem to work best for you? If I mix the supplied 2X256 chips with 2X1G chips with a faster speed will the faster chips be limited by the slower ones? Sorry for all the questions but it's pretty confusing when even E machines tech support can't seem to give me a straight answer? Thanks for the help Mark
    President:
  • 2,961 Answers
Your system may have 2 slots for SDRAM and 2 slots for DDR Ram, and must not be mixed, either use only DDR DDR2 or SDRAM. The mobo may only take 2 of the same size sticks e.g 2 x 1GB,or 2 x 256MB, so be carefull as you may waste money on a non recognised peice of ram. If you use a pc3200 and a pc2700 stick it will run at the slower speedof pc2700. Some boards will only allow a certain maximum of ram up to pc3200 speed and then adding any more you will have to run at pc2700 speed. The crucial memory site will be best for advice on memory type allowance and speed.
Posted on Jan 29, 2007
I have problems with synchronizating files. Well, not with all the files. I have 9 songs I can't sync, if I try to sync them Windows Media Player blocks immedately and so does the player - it loses...
The issue is the file location on windows. When the error message pops up it should give you the option to browse your computer and find the file. If not find the file and add it to windows media player manually. It should fix the errror. or your computer just hates you lol
Oct 18, 2012 | iRiver H10 MP3 Player
Tip
No video on screen
Whenever you run into a situation where you have no video, it can be frustrating cause it can be a number of reasons why its happening.
The most common cause of no video is that dust or dirt gets in the memory slots, sometimes you may not even see it.
The best way to handle this is to take the memory out of the slot. Take a can of air and blow some on the contacts of the memory and also blow some of the air into the slot as well.
This will ensure that contacts on the memory are clean and also it will make sure that the contacts in the memory slot are clean as well.
Then put the memory back into the slot, make sure it snaps back into place and then turn on the computer and you should have video again, this usually solves at least 80% of the problems with no video.
on Dec 02, 2009 | Computers & Internet
Four lights show top-2-green 2-yellow on back of computer No viedo, Green is on, motherboad Awhile back the internet card shortedout,replaced it, I now have no viedo,Computer will not start, Is the...
Hm. Not really, so, just to make sure I understand, the light combination is GGYY [green-green-yellow-yellow]. I'd like to know what model your system is.
If I understand it correctly, GGYY pertains to a memory [or memory slot] problem. You could try to remove all the memory on your system and try it one at a time.
Jul 10, 2011 | Dell Computers & Internet
What kind of memory module is best for a intel d865gmr motherboard, and what is the maximum limit in a slot?
Your particular board is not listed on Intel's site, which means it was a custom version made for some computer manufacturer. So there may be differences between it and the similar boards Intel does list. Checking the specs for other D865 chipset models shows that they can take up to 4GB total, in up to four modules of DDR400 RAM in a dual-channel setting. This means you need to have the same size and speed of memory installed in both banks. The first two slots are the first bank.
Since yours is a custom board, it may not have four memory slots, or there may be special addressing limits. So maximum memory may be less than 4GB. But the basic chipset is the same, so the kind of memory should be as well.
Dec 12, 2010 | Intel D865GBF Motherboard
How much memory can this product of hp take i have cone some test and i think it should be up to 2gb per slots i have try to upgrade it to 4gb and fail i have even try 3gb and fail but it works with 3gb if...
If you are using the XP or Vista OS, if you are going to install more than 3 GB of Memory then it fails to show up on the computer properties.
Once you install the memory then you may check the BIOS for the memory installed in the system, the BIOS shows the exact amount of memory installed in the system.
You system is capable of 4 GB of RAM.
Sep 10, 2009 | HP Compaq 6720s Notebook
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
Just got a couple dell pe6450 memory boards never seen them before how do they connect to sever"
The mobo for a PowerEdge 6450 has 16 slots - four banks of four.
Acceptable memory: PC133 Registered ECC SDRAM DIMMs. Must install memory in fours. (This may be a problem, as it appears you only have two)
A picture of how it should look can be found here: http://www.edgetechcorp.com/memory/upgrade.asp?cid=20616
The first bank of four is probably already populated with memory, just pick the next available 'quad' of slots and install as you would any computer memory.
May 18, 2009 | Dell PowerEdge 6450 Server
Dell Dimension 8400, no post. B and D amber.
GYGY diagnostic lights -- Memory is detected, but a memory configuration or compatibility error exists, and the 1-3-2 beep sound indicates the MEMORY test failed, which means one of the four memory has gone bad or the one of the four slots on the motherboard has gone bad, Neither the memory nor the mother board has completely gone bad, but either one slot or one memory has gone bad, try placing one memory on all slots and check which slot is the issue, then trying placing any 3 memory on the remainig slot to isolate the memory, then after that use the best 3 in the best 3 slots and check, you computer should work fine, this would help you for sure
Feb 06, 2009 | Dell Dimension 8400 PC Desktop
8GB G.Skill F2-8500CL5D-4GBPK in Gigabyte GA-P35-DS3L rev. 2.0
If they are not a matched pair it will not work. If you have two sets of matched pairs. Each pair will have to go into the right pairing slot. Example one set you go in slots 0 and 2 and the other in slots 1 and 3. If you have stickers on the memory sticks look for a group of numbers and letters one group will match it's mate.
Apr 03, 2008 | Computers & Internet
Mmc
Chances are that the software on your phone has become corrupted. I would advise doing a master reset on the phone and see if the problem persists. If that doesn't help...probably the card slot has malfunctioned. Most probably a reset will slve the problem. Good luck!
Dec 19, 2007 | Nokia 6680 Cellular Phone
E-Machines D4362 (RBD4362) PC Desktop Logo
83 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
