Question about HP Pavilion dv9000z Notebook
Recovery partition i have deleted recovery partition did not make copy how can i get it back hp 9655ea
    Scholar:
  • 160 Answers
Contact hp and you can purchase a set from them. there is no other way to fix your problem that i know of short of buying the os cd and getting the drivers from hp.
Posted on Dec 02, 2008
What should I do to rescue lost data from deleted partition?
If you have not written anything on the partition it may be possible to recover part of what was lost. Launch a Google search for some trial data recovery software.
Sep 23, 2014 | Sony VGN-FS740/W Notebook
How to recover HP laptop from usb or recovery partition when winload.exe not found?
don`t loose time.
back up your files....
format and install windows from a disk!
May 06, 2014 | HEWLETT-PACKARD HP G62 Notebook
Deleted partition recovery
You may recover deleted partition from Transcend USB drive with data recovery software, download from
http://www.asoftech.com/articles/transcend-data-recovery.html
hope this helps.
Nov 27, 2013 | Transcend StoreJet 25 Mobile 500GB USB 20...
Can I dl or burn to disc the factory reset for my gateway nv5105u laptop? I have lost that CD
If you have lost the CD you can try to do a factory reset from the recovery partition. Make sure you haven't formatted or deleted any partition in the computer since your purchase.
Using the Recovery Partition to perform Recovery.
First turn off your computer
Turn on the system and keep tapping the F11 key
system will boot into recovery partition. Follow the instructions below:
  1. Boot into Gateway System Recovery - Press F11 to Start Recovery.
  2. On the System Recovery Menu screen, press the ALT+D keys.
  3. At the command prompt, type: D: and then press ENTER.
  4. At the D:\ prompt, type: CD Windows\i386 and then press ENTER.
  5. At the C:\Windows\I386 prompt, type: dir filename.* and then press ENTER.
  6. Verify if the file name has an underscore ( _ ) in the extension. Example: appwiz.cp_. If the file has an underscore, it has to be expanded. If it does not have an underscore, the file can be copied without expansion.
  7. If file has an underscore, expand the file to the destination. At the command prompt, type: Expand filename.**_ C:\Destination. Example: Expand appwiz.cp_ C:\Windows\System32
  8. If file does not have an underscore, copy the file to the destination. At the command prompt, type: Copy filename C:\Destination. Example: Copy atmadm C:\Windows\System32
  9. At the command prompt, type: Exit.
  10. Once back at the menu, click Quit. The computer restarts.
It should be reset to Factory settings.
IF YOU DO NOT HAVE ANY RECOVERY PARTITION OR HAVE DELETED THE PARTITION THEN PLEASE REVERT SO THAT I CAN HELP YOU TO GET A RECOVERY DISC.
Thank you for using Fixya..!!
Aug 05, 2012 | Gateway nv5105u Notebook
I accidentally deleted all the partition when i am formatting the system partition how can i reinstall the OS now where i don't have recovery media.Is there any way to recover the deleted partition?
You cannot recover a lost or deleted partition by simply creating it in Windows Disk Manager (this can only make things worse). To recover partitions you will need partition recovery software Today there are TONS of partition recovery software on the Internet. I am going to give a short review of such software.
Here are some main kinds of partition recovery software:
  • It can be paid or free
  • It can run under Windows or only under DOS (usually from a boot CD)
  • It can give you the possibility to copy files off the lost partition (preferred) or just patch your hard drive (pretty much dangerous).
  • Active Partition Recovery DOS/WindowsPrice: $36Easiness to use: Average
    Safety: Average
    Allows to recover partitions or files in Demo mode: No
    Link: http://www.partition-recovery.com/price.htm
  • or with this free software TestDiskPrice: FreeEasiness to use: Not easy
    Safety: Dangerous!
    Allows to recover partitions or files in Demo mode: Yes
    Link: http://www.cgsecurity.org/wiki/TestDisk_Download Click link to download..
  • but still you can reinstall os on your drive by creating partition..(if no need to recover files)
  • during setup press c key to create partition and put size to what ever you want for C depends on your hdd size.for example your hdd is 80gb,then put size 30000 for C ,then enter
  • the remaining size is for D:scroll down D and press c key to create partion for D:then enter
  • wait till the setup finish
Feb 19, 2011 | Gateway Computers & Internet
How do i delete the hp recovery partition on my maxtor one touch. i am trying to use swissknife to change to fat32 and it says it cant because the maxtor contains recovery files. i thought i cleared it...
I guess you wish to reformat the entire drive? OK you must mount the drive with a partition manager, then you must delete all/any partitions. Then reallocate a NEW partition, 0 to the end cylinder number, format the partition and set it to Active. You should be all OK.
The HP recovery is in a "Hidden Partition" so it can't normally be seen, all that HP does to "Restore" stuff is to mark that partition as active on boot up and the software runs when it boots to that partition.
The only way to rid it is to completely "Flatten" the drive, IE: Removal of every and all partitions and reallocate space to a new one.
Jan 27, 2010 | Computers & Internet
Due to a virus and boot up loop, I have completed a PC Recovery on a Compaq Presario with Windows XP SP 2. The hard drive now has a partition with C maintaining my old files and PR (D) the recovery...
I would back up my data then delete both partitons and format as one drive.. Thats what I would do.. But dont do this unless you have a copy Vista or XP on CD.. The install files for your system are on your hard drive..
Dec 13, 2009 | HP Compaq Presario SR2020NX PC Desktop
Trouble installing xp on a hp pavilion t3000
use the Windows Xp CD to format the hhd twice.
install the OS from the CD without partition.
you can always partition the hhd later.
Jan 13, 2009 | HP Pavilion a705w PC Desktop
HDD data recovery
most hard drives have that erie only 2 partitians at a time this is with your computer how it can handle since you made three particians there is a chance that it only allows partitions of only 2
say for instance you have a celeron your comp would only allow what you memmory can give you this would knock out the 2 partician when created the 3rd partician
not enough memmory to fill all 3 partitians
safe end to this particians in long run can hurt your comp more than help it i suggest buying another hdd to make your back ups or get a portable pull out system hdd this ensures your files are as easy to get as putting in a new hard drive
hope this gave some insite
Apr 29, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
