Question about Teac Audio Players & Recorders
I have a Teac reel to reel Model X-7R MK2. When it is rewinding the take up spool runs slower and slower until it nearly stalls. Supply voltage to the take up spool goes down to about 9 volts What I would like is a schematic for the control PCB-116
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Sorry no free download of a schematic. If I may share some ideas, DC voltage going down could be caused by leaky/faulty capacitor, regulator transistor or the motor itself.
Might be of help, the complete service manual (for a fee).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 02, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Genius:
  • 1,550 Answers
You need to buy service manual for this .
You can get one from this website
Service manual
Old Teac A601R not working, when you place a tape in it just stops automatically. Is it worth trying to find out what's wrong or is it to old. When you place in a tape and press play it goes forward then...
The unit can be fixed in the right hands. The auto rewind function might be on but the reel rotation sensor is not seeing it move. Probably needs all new belts.
Sep 16, 2013 | Teac Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
How to start to play
Go here for a picture:
http://www.proaux.com/TEAC-A4010-GSL-Reel-to-Reel-Recorder,name,1638,auction_id,auction_details
http://www.angelfire.com/electronic2/vintagetx/index.html
The two arrow buttons on either side of the FAST key will play it Forward or Reverse. Combining the FAST key with a direction initiates a fast forward or rewind.
May 16, 2009 | Teac GF-600 Turntable
''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Apr 08, 2009 | Audio Players & Recorders
Teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
Jan 23, 2009 | Audio Players & Recorders
Rewinding a tape
Theres a rewind ,fastforward clutch inside the tape mechanism thats worn, the brake for the supply reel in not releasing completely, or theres hair -dirt- or gunk under the supply reel, or the drive belt needs to be replaced. Now If this wasent part of a tv set combo I would say take it apart and have a peak at some of the things I mentioned. BUT theres extremly HI VOLTAGE inside this puppy and if you dont know the saftey issues related to this , I would highly recommend getting a pro to assist you in this repair. Good Luck
Jun 27, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
26 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
