Question about Frigidaire FGB24S5A Gas Single Oven
Oven won't work
When i turn the oven on it says F3 so i don't know what the problem is can you help.
  • Frigidaire Master
  • 2,651 Answers
The oven sensor needs replacing, 2 secrews hold itin its locared in the upperleft hand corner on oven cavity, pulls right out and new one plugs in.
F3 Oven temperature sensor open Replace oven temperature sensor
Posted on Dec 02, 2008
F3 error code
Bad oven temp sensor. If you know how to do so you can disconnect the power and remove the temp sensor. The two white wires to the sensor, ohm it. it must read ~1080 ohms. If not really close to that at room temp then replace sensor.
Dec 11, 2013 | GE Profile JT955 Electric Double Oven
RS696RXBQ2 - won't heat up, get error message F3 then shuts off.
This tip i wrote explains what the F3 error codes means and what to check to fix your oven.
Sep 12, 2011 | Whirlpool Ovens
Stove reads F3 and won't cancel and oven won't shut off?
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Jun 15, 2011 | Frigidaire Ovens
Showing f3 high on display
F3 stands for a faulty oven sensor. Unplug the oven, then replace the sensor. Should be back to normal. The sensor is inside the oven. When you pull on the sensor, you'll get to a male/female quick connector. When you unplug it, be careful not to lose the other end behind the oven wall or this simple repair won't be so simple anymore. Check here the replacement sensor for your oven.
Hope this helps.
Jun 14, 2011 | Ovens
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
What does F3 mean from my Kenmore Oven??
f3 is a bad sensor part number WP8053344 this reads the temp. in the oven just like on older ovens had a thermostat.if you look into the oven you'll see it go here and look at picture
go here to see error codes
Nov 13, 2017 | Kenmore Ovens
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Error code F03
although i don tknow what model your talking about all the F3 codes in ovens is pointing toward bad oven sensor, replace oven sensor
Mar 16, 2008 | Ovens
Oven turns off F3 flashes
Bob, an F3 error code denotes a failed oven temp sensor. See below.
F3 Open oven temperature sensor circuit Replace oven temperature sensor
The repair is pretty straight forward, but you should have the replacement part in hand before you begin. The part number is WB21X5301 and retails for about $95.00. I just found one online for $72.60!
The sensor is located inside the oven cavity mounted to the top of the rear wall. Remove the 2 screws and slide it out of there. The sensor has a plastic connector connecting it to the main harness behind the oven. Pull this carefully through the hole. If you can't get the plastic connector through, then you'll have to pull the oven and do this from the back... alot more work but still do-able. Simply disconnect the old sensor from the plastic connector and install the new one. Then feed the wires back into the oven and re-mount the new sensor.
If you don't have to pull the oven, the job should take about 20 minutes and all you need is a 1/4" nut-driver or socket.
If you have to pull the oven, re-post and let me know... I'll walk you through it.
There ya go!
Aug 22, 2007 | GE JGRP17 Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
61 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
