Question about IBM NetVista A40 PC Desktop
Machine won't recognize CD-ROM after harddrive format
The machine was low-level formatted, and I need to have it boot up with a Microsoft XP install CD. However it won't recognize the CD-ROM at all. I switched drives with another functional machine, and eliminated the drive as the problem. I then switched the ribbon cable with another functional machine and eliminated the ribbon cable as the problem. I've checked the Startup Utility, at its configured as having a CD-ROM installed. Yet I can't seem to get it to work. Every time it boots up, it seems to ignore the drive and only look to the floppy for the operating system, and displays the basic "put floppy in drive and press F1" pictoral diagram. Any ideas why the machine won't see the CD-ROM drive and how to get this problem resolved? Thankx in advance!
Re: Machine won't recognize CD-ROM after harddrive format
No because the the arrows don't change the sequence nor does the plus or minus. i'm stuck.
Posted on Oct 21, 2008
  • 2,961 Answers
You have to change it in the bios, press F2 or DEL on startup depending on your bios type. The bios screen then will have second line of advanced bios settings, in here you need to select the cdrom as the first boot device, by using the up down arrows or pageup/down or '+or-' keys. Press ESC when cdrom selected and save settings when propmted. The system will re boot so ensure the cd is in the drive and press enter when prompted to start with cdrom.
Posted on Jan 29, 2007
0 characters
3 Points
First i have windows xp and i wanted to format it, but it didnot booting from cd drive. So i decided to set up new xp through harddisc. Because i already have a copy of xp in my harddrive and i clicked the...
insert your os cd and boot it from cd rom by pressing either f5,del or f12 depending on your machine.if it does not boot,try replacing the cd rom.good luck
Mar 16, 2012 | Acer PC Desktops
I have an acer power fg and i just installed a power supply and a new harddrive now is giving me problems to format the harddrive it says to reboot or media doesnt let me install windows xp help
Well , Insert the windows disk , make sure the boot priority is set to CD/DVD ..boot the windows xp disk and format the hard drive using NTFS full format.
Please reply for any furthur issues
Nov 18, 2010 | Acer Power FG (APFGUP5161) PC Desktop
Will not boot cannot get to safe mode if I do a recovery will I lose all data files, not going to do advanced
from my exp recovery CD is of no use at all....if ur OS is corrupted.....use a WinXP install CD and boot from that. to do that...insert the CD in the CD/dvd drive and switch on...if the boot seq in BIOS is set to CD drive then it will boot first from that else it will boot from if u can get into BIOS by pressing the F1/F2/Del key etc and change the boot seq to the foll:
1st boot CD rom
2nd boot Floppy
3rd boot HDD0
u can even just disable 2nd and 3rd apart from keeping 1st boot to CD rom
if u have more than one HD or more than one partition in ur HD then u can install a new fresh Win XP in that and once that's done then change the boot seq back to HDD0 from CDROM drive in the 1st boot order
it will get back ur machine live then u can copy all ur imp files to a pen drive or CD then once u r safe of ur data u can do a low level format of the full HD and then aprtition that as per ur requirment
Feb 11, 2010 | HP Pavilion a1610n PC Desktop
Error loading o.s windows xp
If you want to try booting from safe mode, start the machine and press F8 until you get a boot menu, but you getting the 'Error Loading OS' message sort of suggests your relative may have wiped the harddrive before handing the machine off to you, which would mean there will be nothing there to recover from.
Sounds as if the PC is set to boot from the harddrive, so your easiest fix would be to get into the bios settings at startup and set your 'boot order' to read from your optical drive (cd or DVD) first- Put YOUR copy of XP in and away you go!
Another option would be to go to bootdisks,com and download a Win'98 boot floppy image with CD-Rom drivers, & unzip the image to a 3.5 floppy, but that's the long way around.
Oct 07, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Iam working on a compaq pc desktop had windows xp with pen4 iam trying to install a old harddrive i had in a pc that had windows 98 how do i clear all the old thing,s out of the harddrive so i can install...
ok ...the issue is only that it might recognize the operating (win98) system if its installed on it ..if it was just a slave there will be no problems..just attach it ..on the bus and power ...and boot the system ...if you want you may use a partition magic program to format and rename it ...but you can do that with the xp clicking right on the drive in my computer and format from there ... if it doesn't want to format it ..just boot from the installation cd ( xp) and continue like a normal installation until you are at the point where you have to choose the partition to install the program ...choose the new added hard disk and format it deleting and reformat ....but after this just stop the installation and restart the old OS ...but I'm sure that you will be able to format it quick from xp directly , just attach it and my computer to see if it sees it ..and format
Jul 31, 2009 | PC Desktops
Replacement harddrive into acer pc
No matter what you do, you need to partiton and format the drive and install an OS, be it with the Acer recovery disks or with an original XP install disk. You will need to boot from your CD drive to install the OS, if your drive is not bootable you will need to boot from a floppy and load drivers for the CD drive. For information on how to get these boot floppies check out this Microsoft link:
Apr 13, 2009 | Acer Aspire T310 PC Desktop
Reformatting E-machine desktop computer W3115
Insert the CD to the CD ROM. Set the bios setup to boot using the CD-Rom. Space bar while booting up. If you got the setup press F8, choose NTFS to format the drive. Then go on with the Installation.
Mar 10, 2009 | E-Machines eMachines Desktop PC
When booting up select whichever key gets you into the Bios. Normally either F2 or delete. Once in the Bios, find the boot up sequence and by the instructions that will be there to change the sequence change it to Floppy Drive, then CD Rom, then your hard drive with Windows on it. Press F10 to save and reboot.
Nov 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
IBM NetVista A40 PC Desktop Logo
560 people viewed this question
Top IBM PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you an IBM PC Desktop Expert? Answer questions, earn points and help others
