Question about Bosch Electric Table Saws
Bosch 4000 tablesaw suddenly ran backwards and died
Was operating my Bosch 4000. After ripping 3 thin pieces, the unloaded motor started to run backwards, then died. Won't start now. Outlet is fine. Checked the bearings, which look fine. This saw has been very reliable for the last 4 years. Could this be a capacitor or controller issue?? Thanks for any help.
  • kentzollars Apr 02, 2009
    My saw just did the same thing. I was ripping a 2x6 & It then it started to run backwards.
I had a customer bring me a saw with this same problem. All components tested OK on my growler. I went on a limb since the speed control and the armature tested OK. I replaced the feild since to me it seemed to be the only component that could cause the motor to run in reverse. Tool now works properly and have had no more problems with the tool.
Posted on Jun 16, 2009
    Sergeant:
  • 359 Answers
Bad motor
Posted on Dec 03, 2008
Bosch 4000 table saw motor schmatic
http://www.ereplacementparts.com/bosch-4000-0601476139-table-saw-parts-c-128_167_168.html
I have found the most common issue is a bad field with the second being a bad rear armature bearing and last being a bad speed control.
Most of the time slow speed or even running backwards is a bad field (part #2 on the breakdown) #1619PA5590
Remove the cap on the end of the motor & the 2 carbon brushes.
Remove the 4 screws holding the motor to the frame and pull it straight off.
Check the bearing on the end of the armature to ensure it is not frozen or stiff. If it is also check the rubber boot that sits over the bearing and the motor housing itself to ensure it is not melted.
Dec 18, 2013 | Bosch 4000 - 07 Electric Table Saws
Bosh 4000 table saw runs backward and at low speed
I've worked on some table saws with problems like you describe, a couple needed a new speed control unit (Bosch PN 2610997306) in the motor. If all the wiring to and inside the motor is OK and not shorting out anywhere, that's the next part you should look at.
Jul 10, 2012 | Bosch 4000 10IN Table Saw
I need help wiring in a new speed control on my bosch table saw 4000. The new speed control came with a large black wire, a small black wire and a small blue wire. The large black wire was easy and I...
ts4000 Bosch motor wiring (post #210578, reply #6 of 7)
by emils01 in reply to emils01 [original] on Tue, 09/30/2014 - 15:50
So I called Bosch on Monday and they were well informed and helpful. They emailed me a schematic and explanation of ...
4000 PCB wiring diagram.
1. White AC line cord to white field wire.
2. Black AC line cord to thin blue wire on PCB.
3. Black motor field wire to thin black wire on PCB.
4. Black long, thick wire on PCB to red motor brush wire with push on connector.
Sep 18, 2017 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 Table Saw running backward
You can find the 4000 manuals and parts diagram at bosch tools online. You will need a new armture Bnew bushes and possibly field. I would also replace the bearings and motor speed control circuit board.
Bosch does not sell the motor assembly.
Turn unit upside down and remove the Plastic body - approx 6 screws.
Thake a digital camera and take LOTS of pictures of dissassembly as you will need them later. Blow unit clean and work neatly keeping all parts in labeled bins for reassembly. Don't attempt this job when your pressed for time.
Before you start check to see if this machine is still under warranty!!
Call customer support listed on website if you run into a problem.
Good Luck !!
May 19, 2010 | Bosch 4000 Factory Reconditioned 10"...
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
What's the smart way to remove the motor for
i wouldn,t remove unless you think needs new bearings or cannot get to the brushes, turn upside down if has base cover remove and blow out best you can be sure no water in air line.
Jan 05, 2010 | Bosch Electric Table Saws
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
does it have original oil in it? if so they use a lighter weight oil than recommended for engine break in. change your oil and filter and see if that doesnt solve it.could be thinning out loosing pressure when hot. i have seen this beofore.. :)
Mar 24, 2009 | Watts Onan Portable Generator - 4000 ,...
My tablesaw wont speed up and run. Bosch 4000 ten inch. It makes a klunk and starts to turn and slowly speeds up until its running, but still makes a knocking sound
Is it spinning the blade at all? If it is then it is unlikely to be an electrical fault. Have you considered a motor bearing fault? If the motor bearings are worn, it could turn freely by hand, but when powered up it would stutter and stall. The motor is basically a big electro-magnet so if the armature has enough lateral movement, when it is magnetized it could rub against the stator.
If the machine is buzzing, but not spinning the blade it is more than likely going to be caused by a faulty capacitor as this is the component that gives the motor the initial 'kick' in the right direction to get it spinning.
Nov 03, 2008 | Bosch Electric Table Saws
Bosch 4000 tablesaw
the parity is switch. which means its positive and negatives are switched.
Oct 23, 2008 | Saws
Bosch Electric Table Saws Logo
842 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
