Question about Zenith B32A34Z 32" TV
ZENITH THE PICTURE ON MY TV SET IS VERY DARK - THE BLACK IS VERY BLACK I CAN NOT GET THE PICTURE ANY LIGHTER - HOW DO I HAVE MY TV CLEAN INTERNALLY?
    Scholar:
  • 150 Answers
Your tv does not need an internal cleaning for brightness, I suspect that your tube has aged and either needs an adjustment or replacement.
Posted on Jul 07, 2007
Turns on dark and then gets lighter
ic circuit is the problem, see TV Tech.
Nov 09, 2013 | RCA F32650 32" TV
Picture "flickers" from dark to a lighter
This is a board level fix.
The part is about $10. + time to solder on the part
Capacitor C809 is failing.
390mfd @250V
Mar 05, 2011 | Proscan 42LA30H 42 in. LCD Television
No picture, black screen
Not a TV Technician, use the following information at your own risk. Two things you can do first: using the keys on the front of your set press and hold the menu button when while holding it down it goes from menu to channel listing press the adjust (<->) and channel up buttons simultaneously to get to the factory set up screen once there use the select button to scroll to next set up screens locate the contrast it should range from 1-63 find the one you like. Second: for the horizontal lines not to say that this is the solution there are two adjustment apparatuses inside the TV chassis if your familiar with taking the set apart and not getting shocked and hurt59274cc.jpg two dials on the fly back transformer ones for focus the other brightness you can try these fixes but I have to say again that you use at your own risk. I do hope though that the information is useful
Mar 18, 2009 | Zenith B25A02Z TV
Blurred picture and it's also dark rear projection zenith Z52Z95D
I'd get the lamp replaced for sure. If it has a ballast - change that at the same time. However, a Zenith repair center should be able to tell you whether it's worth doing or not.
Jan 05, 2009 | Zenith Z52Z95D TV
Zenith Projection Tv Set Model number ZB4685T no Visual
Since this is a CRT based set, there could be a number of problems. What exactly do you mean when you say that the picture fades? Do you loose contrast and the picture gets lighter? or does the picture darken toward black?
Parts are still available, so this can be fixed. If youfeel you want to attempt this yourself, please supply additional info and we'll walk down the diagnosis path.
Dan
Aug 08, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Dark picture, mostly red colors
if you set is over 4 yrs old the tube is at fault,you may try to adjust the screen settings.
Mar 27, 2008 | Zenith B25A76R 25" TV
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Zenith rear projection TV
it's unual for all 3 crt's to go bad at same time, so have you tried turning up screen(G2) control? If so also there is a cap in the high voltage line that when replaced may lighten up set. Don't have model so I can't go further.
Aug 11, 2007 | Zenith SY2768S TV
Picture is VERY dark...
zenith have many problems with crt (picture tube) they comes be short or one or more canon fail, there are nothing to do, replace the picture tube, and thats a lot of money for an old tv...good luck ps adjusting the screen and resoldering the picture tube card could help but remember there are many dangerous circuit in a tv...
Aug 10, 2006 | Zenith C27A24T 27" TV
Zenith B32A34Z 32" TV Logo
133 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
