Question about Whirlpool Duet GHW9150P Front Load Washer
Whirl pool dryer LEC9000PW0 will not turn on
After checking the thermal fuses, checking the door switch and checking the start switch I replaced the motor. Dryer still will not turn on. The light in the dryer is on and turns off when the door is closed. I can hear the timer going.
  • 26 Answers
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Posted on Dec 20, 2008
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
Dryer will not turn on after button is pushed.
HI, check the following to address this issue.
The dryer will not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jan 08, 2010 | Magic Chef CYE4000AWW Electric Dryer
Dryer won't start, timer makes clicking noise drum sometimes begins to turn but does not come on.
3. Thermal fuse
**The most common issue here will be a defective Thermal fuse, but in this case, the door switch may be the culprit. Check all the areas stated above to cover all suspect issues
Sep 30, 2009 | Kenmore 73952 Gas Dryer
Gas dryer does not turn on , first it would not heat. but it did turn on and blow air but no heat . know it doesnt turn on at all.
3. Thermal fuse
4. Timer
Sep 03, 2009 | Kenmore 73952 Gas Dryer
Kitchenaide dryer won't turn on. . .
3. Thermal fuse
4. Timer
Aug 06, 2009 | KitchenAid Dryers
My dryer wont turn on at all, is there a internal fuse?
3. Thermal fuse
4. Timer
**(((The most common issue here will be a defective Thermal fuse)))
Jul 30, 2009 | Dryers
Our whirlpool 6th sense dryer model awz3413 will not turn on
3. Thermal fuse
4. Timer
Jul 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Will not turn on
3. Thermal fuse
4. Timer
Jul 10, 2009 | GE DWSR463EGWW Electric Dryer
Dryer will not turn on.! It shut off by itself while doing a load and i have not been able to turn it back on since.
3. Thermal fuse
4. Timer
Jul 04, 2009 | Maytag Performa PAV2200
Drum doesn't turn, start switch turns dryer on when held on but dryer shuts off as soon as start switch is released.
3. Thermal fuse
4. Timer
Dec 02, 2008 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
903 people viewed this question
Dan Webster
Dan Webster
Sal De
