Question about Prima C1310B 13" TV
Are prima tv's digital ready?
Do these tv's have digital tuners?
Or, will they require converter boxes?
  • ron1944g Feb 21, 2009
    How do we add channels to our tv? we now have ch6 ch10 ch3 and can't figure how to add 31//47//18//53///18//23 . We are located near Jackson, Michigan and we can get all of these on our big tv but unable to put on our prima in the den. H E L P
  • 73 Answers
If the channels show up as 4-1 4.1 "an example"
then yes it's digital!
Posted on May 23, 2009
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Jun 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Polaroid Model TLX01911C
Greetings!
This set is listed as having the ATSC (Advanced Television Systems Committee) tuner. This tuner provides reception of digital over-the-air (antenna/rabbit ears) signals and would therefore not need a converter box fir that use.
If you are trying to receive un-encrypted digital signals from cable, the ATSC tuner does no good. The set would then require a QAM (quadrature amplitude modulation) tuner. I am not sure if this set has a QAM tuner or not. Even if it did not, your cable provider must provide a way for you to receive their signal and should make their converter box available to you.
Hope this helps explain things a little,
Rob
Jan 14, 2009 | Polaroid TTM-2003 Combo
Digital boxes
This model only has an analog tuner, so you will require either a converter box or hi-def tuner after the transition.
Dec 07, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Does my TV have a digital tuner?
If your portable set was made before March 1, 2007, then it almost certainly does not have a digital tuner and would require a converter box. (After that date, the FCC requires all TV's to have the digital tuning.)
Nov 30, 2008 | Televison & Video
I have TV Model #DS27425. Does it have a built in digital tuner, or will I have to buy a box to be ready for HD TV? Thanks. daisypc@insightbb.com
This particular set does NOThave a digital tuner. However, if you have cable or satelite, a converter will not be needed. Only if you use an external antenna will you require a converter box.
Dan
May 08, 2008 | Televison & Video
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Prima C1310B 13" TV Logo
186 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
