Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP6210 printer, poor black print quality
It appears that every other print line, when only printing with black ink cartridge, is faded. The words, when printed, appear with a blank line through the middle.
I have tried 2 brand new cartridges. The color print quality is just fine. I have tried to clean the cartridge and align the cartridge - with no improvement in quality.
  • rurora Jan 14, 2009
    When printing in MS Word 93 or Excel 93 every other line or so is either faded or missing. Test page prints fine. I've uninstalled and reinstalled the software, done the cleaning and it still is messed up. It prints color fine and other print jobs are also ok for eg. Google map directions.
  • Anonymous May 01, 2009
    I have exactly the same problem. The black cartridge prints either a faded or no line at all. The color prints fine.
hashchathy
  • 246 Answers
SOURCE: poor print quality - top half page okay, bottom print faded and skips
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Posted on Aug 01, 2008
  • 141 Answers
SOURCE: HP Laserjet 4350dtn Print Quality poor
Most likely the fuser has lost part of the teflon from the heat roller. Having said that, the first step in any print quality issues is to change the toner cartridge. good luck!
Posted on Aug 26, 2008
SOURCE: Will not print black , HP PSC 1610 All-in-One
Here was the solution. You MUST use HP brand black cartridge. Originally I purchased a #94 Office Max brand black cartridge. After it did not work I took it back and they gave me a second Office Max brand and that did not work either. So I took it back and they sold me an HP brand (I only needed to pay the difference in price so Office Max was good to work with). I installed the HP #94 black cartridge and everything now works.
Posted on May 11, 2009
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Posted on Jun 16, 2009
  • 398 Answers
SOURCE: Ricoh cl3500N printing with blank streaks in
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
Posted on Jun 28, 2009
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
I have been told my printhead is malfunctioning. Can I clean it myself?
You can look in thr user guide or printer help for Troubleshooting and Routine Manteinance.Make sure that the Printer Driver or Paper Type setting in the menu matches the
type of paper you are using. (See Printing in the Software User's Guide on the CDROM.Make sure that your ink cartridges are fresh. The following may cause ink to clog The expiration date written on the cartridge package has passed. (Cartridges
stay usable for up to two years if kept in their original packaging.) The ink cartridge was in your machine over six months.The ink cartridge may not have been stored properly before use.
Try using the recommended types of paper.
CLEANING:
Press Ink.
Press a or b to choose Cleaning.
Press OK.
Press a or b to choose Black, Color
or All.
Press OK.
The machine cleans the print head.
When cleaning is finished, the machine
will go back to standby mode
automatically.
Checking the print quality
If faded or streaked colors and text appear on
your output, some of the nozzles may be
clogged. You can check this by printing the
Print Quality Check Sheet and looking at the
nozzle check pattern.
Press Ink.
Press a or b to choose Test Print.
Press OK.
Print Quality.
Press OK.
Press Color Start.
The machine begins printing the Print
Quality Check Sheet.
Check the quality of the four color blocks
on the sheet.
Is Quality OK?
1.Yes 2.No
Do one of the following:
If all lines are clear and visible, press
1 to choose Yes, and go to step j.
If you can see missing short lines as
shown below, press 2 to choose No.
The LCD asks you if the print quality is
OK for black and three colors.
Black OK?
1.Yes 2.No
Press 1 (Yes) or 2 (No).
The LCD asks you if you want to start
cleaning.
Start Cleaning?
1.Yes 2.No
Press 1 (Yes).
The machine starts cleaning the print
head.
After cleaning is finished, press Color
Start.
The machine starts printing the Print
Quality Check Sheet again and then
return to step e.
Press Stop/Exit.
If you repeat this procedure at least five
times and the print quality is still poor,
replace the ink cartridge for the clogged
color.
After replacing the ink cartridge, check
the print quality. If the problem still
exists, repeat the cleaning and test print
procedures at least five times for the
new ink cartridge. If ink is still missing,
call Brother Customer Service
Nov 03, 2010 | Brother Multi-Function Center MFC-240C...
Printing part words, fading print quality
there are 2 cartridges in for this printer, have you tried replacing both cartridges with new ones?
If yes then your printer needs some maintenance too
Mar 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Poor print quality and I don't think it's the ink cartridge
TRY TO ADJUST THE MANAGE COLOR LOCATING ON YOUR COMPUTER FIND IT AND ADJUST THE DARK COLOR
Dec 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Dell Computer printing issue
If the documents are actually printing, the problem is most likely with the printer(s). Poor print quality is almost always a result of problems with the printers or their printing supplies (toner, ink cartridges, paper, defects or debris on rollers creating streaking, etc.).
Mar 21, 2009 | Dell Dimension 3000 PC Desktop
Won't print but few lines til black fades out
It pretty much sounds to me like you have "outdated" or old cartridges. Are you using the photo setting to print photos? Before you purchase more expensive cartridges do a head cleaning! Good luck.
Dec 16, 2008 | Dell 924 All-in-One InkJet Printer
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
