We have a whirlpool washing machine. It will not run through a complete cycle. Under regular, or delicate, or any other cycle it only completes part of the wash cycle and then it stops. Any ideas?
Problem fixes. Lid cover switch needed replaced. Thanks. Rick
Posted on Dec 02, 2008
My Whirlpool Washing Machine W10560167A restarts after completing a wash cycle. Is their any way to fix this problem or why it keeps restarting?
Need model # that is apart # or diagram number the unit is programmed for continous run provide model # will explain how to take out of this mode
Sep 25, 2014 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    Whirlpool 4213632 wont drain water on perm press or delicate
    check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
    Feb 11, 2010 | Washing Machines
    Whirlpool warher
    This is another pump problem, it will keep pumping if it thinks there is water coming through, pump cycle should only be about 30 seconds.
    Oct 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    The 7kg hoover will wash then stop agitating
    There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
    If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
    Oct 08, 2008 | Hoover HTC243 Top Load Washer
    I have whirlpool washer model LSQ9549LQ2. It has burnt timer which I replaced. But now when I run washer it run only from one position from timer. Need help
    Thanks for your question If your timer works in one cycle only say on the regular cycle You could have a defective one . If your washer has 2 speeds the delicate speed on your motor could be the problem
    Jul 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    67 people viewed this question
    Top Washing Machines Experts
