Question about Hitachi 60UX54B/55K 60" Rear Projection Television
Hitachi 60ux58b I have asked this before but looks as if you are on top of your game..OK Put in the c707 and e994 everything went ok..But same issue green lights light up for a short time then go out all togrther..The RED peotect light comes on flashing.There must be an easy fix or a way to test the system..I am by far a guru but if you could help me,it would be great..I have tried pretty much everything ..Is there any place that repairs these boards..Thanks for you help
  • Hitachi Master
  • 5,138 Answers
Let me do some checking and i will get back to you! You still have something open have you ck the pico fuses if one of them is open set will not come on. they look like green resistors but are fuses
Posted on Dec 13, 2008
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Power issue
Check all the other pico fuses on the board. One or more may also be blown.
Nov 26, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi 50UX58B
hello . rember me .? I told you to replace the hole board.!!! and we will go from there.!!! WELL you did not get back to me.!!! and you rated me as just helpful. !!! well tell me did it not fix's your set .& make it work now. !!! Right.!!! so if you think about it . YOU DID RATE ME RIGHT.!!! YOU SHOULD OF RATED ME AS FIXYA. . BEOUSE IT DID FIX YOU AND YOUR SET WORK NOW.!!! AND IT DID NOT BEFORE. YOU NEED TO CHANGE MY RATING TO FIXED YA,. ANFD THEN WE WILL GO FROM THER AND WILL LET YOU KNOW HOW TO FIX YOUR OTHER PROBLEM'S YOU HAVE NOW. THANK YOU "GOOD LUCK"
Oct 01, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hatachi 60 inch big screen test port e994 open high voltage shutedown
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B). The kit includes the E994 pico fuse and the C707 capacitor.
Jun 24, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 60sbx78b Won't Turn ON...need advise
If cap value is 1000 pf ( 102k ) 2KV, beef it up ! I use Sony part # 1-161-754-00 ....102k 3KV.......Note: sometimes shorted cap
is hiding under dried gob of placement glue............
Make sure pico fuse is correct amperage.......T.
Jan 28, 2008 | Hitachi 60SBX78B 60" Rear Projection...
HITACHI 60UX58B
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jan 13, 2008 | Hitachi 60UX58B 60" Rear Projection...
No power
You need to check E991, E994, Q777, for more info ctechnicians.com
Jan 09, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Won't power on
Linda,
A VERY common problem with this unit is a small blue disc cap C707 (102 @ 2kv) tucked in front of the horizontal output transistor. It usually has a small pin hole burned in it when it goes out. The cap is actaully part of the scan circuit and it changes in value over time and becomes unstable then opens, usually taking with it E994 a small pico fuse.
I wouldn't spray too much duster in there for all the dust it will create. You'll be dusting the house for days. But it won't hurt using a can of duster or air to blow it out if you want...
Bill
Nov 27, 2007 | Hitachi 60UX58B 60" Rear Projection...
Hitachi TV will not turn on.
If have already unplugged and waited for atleast 15min. and still no success. Then only if you are Electronicly inclined. Check to see if you get dead completely or you get an indicator light momentarly. Which these are two different symptoms. first dead no indicator. check R931,E994,Q777. Then if indicator light comes on and goes off, check E994 which is fuse opening, C707-1000pf 2kv cap, also check D915, I601, IK04, and 05
Aug 15, 2007 | Hitachi 55FX48B 55" Rear Projection...
Hitachi 50ux58b
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
110 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
