Mouse installation going wrong
Bought new laptop, also bought matching HP bluetooth mouse....have tried 3x to set it up. I put the setup disc in, works fine, get to the screen where I have to click on two links and follow the directions to complete the setup. The first link goes fine but the 2nd linke does not (the ''pairing'' link). I click on it and it goes for a second then I get a message saying ''cannot find BtCoreIf.dll'' or something similar about not locating that component. It then says that re-installing should fix the problem...except that it hasnt as I tried twice after that. Help!
  • ruben barrera
    ruben barrera May 11, 2010
    what type of laptop? make/model
  • Greg Wilkins
    Greg Wilkins May 11, 2010
    have you checked compatibility of the software your using? Is the software made for your operating system?
Bluetooth keyboard setup
Try Dell's website to get the latest driver for the version of your operating system.
Sep 08, 2014 | Dell Computers & Internet
Why Genius traveller 6000x Brand New WONT WORK?
you may need to first add a bluetooth device to ur pc/laptop.
There's usually a "synch" button on the mouse..check underneath where the batteries go..it may be larger, if built to follow the design of the mouse or it may be smaller if its "clearly a button".
You need to attach the bluetooth dongle to ur pc/laptop, then after the drivers install, press the synchchronize button on the mouse.
Jun 11, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
HP a6412p added 2nd hard drive but wont work get blue screen
you should try switching the sata port you plug your new drive into. also, you should go into your BIOS setup f2 and save setting then exit.
Jan 25, 2010 | HP Computers & Internet
Synchronize new wireless mouse with my laptop - both Mac
Go to system preferences then to keyboard and mouse then click on the bluetooth tab, at the bottom right of the screen is "Set Up New Device" click on this and the Bluetooth Setup Assistant will come up. Follow the instructions and you will be able to setup your mouse. Hope this helps.
Oct 17, 2009 | Apple Wireless Mighty Mouse
Just bought a new laptop. Bought the matching HP bluetooth laser mobile mouse to go with it. Have tried setting it up twice, exactly following the directions. After I get the setup disc in I get to the...
Could be a defective disc. You could try 1.copying the entire disc to a temporary folder on your hard drive and running setup from there, 2.check the manufacturers website for a downloadable version.
Dec 02, 2008 | Computers & Internet
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
Asire 5630 bloototh activation
may be your computer has no bluetooth adapter that came with it.
i suggest you go to the shop that you bought the computer and ask them if your computer is bluetooth compatible or not.
cheers...................
Jan 23, 2008 | Acer Aspire 5630 Notebook
Open Questions:
Computers & Internet Logo
David Payne
David Payne
