SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch
the positive (+)end of the 9v battery to the positive (+) end of the
camera battery.Leave them touching for a few seconds (10 seconds should
be more thansufficient). Seems these lithium-ion batteries are subject
to a'digital memory.' Subjecting it to a volt surge almost three
timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
SOURCE: Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
