Question about Dishwashers
GE Dishwasher popping sound then smell of burning, flash of light
While the dishwasher was running I heard a popping sound. The dishwasher tripped the outlet closest to it (for garbage disposal also) AS WELL as the main fuse. Checked inside and everything looked okay. Hadn't finished it's cycle.
When the main fuse was reset the dishwasher door was OPEN and I heard the POP again as well as saw a spark(?) of light come out of the bottom. It's 8:30pm - what should I do? Turn off the main again (it didn't trip of the 2nd time - just the outlet). Take of the bottom panel to make sure nothings smoldering under there? I called Factory Service - they said to disconnect - what I'm an electrician now!! LOL
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
SOURCE: loud bang and fusing dishwasher
chucked it !!
Posted on Nov 16, 2008
SOURCE: dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Posted on Dec 02, 2008
SOURCE: dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Posted on Jan 09, 2009
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Our GE dishwasher has been working fine for years. Now it is tripping the braker? all wiring is good right to the dishwasher. We did smell burnt wires but it went away.?????
Your dishwasher may be damaged beyond repair. When I installed the dishwasher in my home I found that there is a surprising number of wires bundled under the dishwasher. If you are skilled in that field you can pull the dishwasher out and try to repair the damaged wiring under the machine. However once you've smelled burned wiring it means that there are potentially significant problems in there. You aren't smelling the burnt wires anymore because the damage is so great it's just tripping the breaker. If you continue to try and force the machine to work in this situation you may end up with a fire and further damage.
Please be careful.
Apr 06, 2011 | Microwave Ovens
Hi there, I have a Tricity bendix dishwasher, approximately ten years old. the other night in the middle of the wash cycle, it went pop, tripped the mains at the board and there was a smell of burning in...
You know, I think the best thing to do would be to replace the dishwasher. It is ten years old and a new one would be more energy efficient and you would save money in the long run.
Jun 29, 2017 | Tricity Bendix Dishwashers
Our dishwasher made a loud pop the other night, and there was a smell of burning plastic/rubber. Since then it has stopped working. No fuse was blown or tripped it seems to be local to the machine. I...
You would probably need a whole new motor but the nwith the smell of plastic you may also have a burn hole in the tub. Your best bet is to replace the whole thing. Sorry
Aug 03, 2010 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Dishwasher not getting water.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Nov 16, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Blows fuze and has burnt electrical smell
Time for a new dishwasher. Had the same problem. Tech came out and threw hundreds at it cause it was under warranty at the time, i didnt pay a dime and ended up buying new one.
Jun 04, 2009 | Fisher Dishwashers
Dishwasher has a smell and all the water is not being pumped out
There is a product called " Dishwasher Magic " to clean, deodorize, and disinfect dishwashers. Hardware, appliance parts, and possibly grocery stores should carry it. It comes in a rectangular 12 once bottle.
Also, check to see that the drain hose loops up higher than the outlet into the drain so no water will run back into your dishwasher from the drain or disposer. Plugged up pump inlets and on some models a degraded drain pop up valve will also result in excessive water remaining in your dishwasher. You didn't state you model number in your post so I can't tell if your machine has one of those.
May 30, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Dishwashers Logo
544 people viewed this question
Top Dishwashers Experts
