Question about Kitchen Ranges
RCA oven bottom heating element burned up
I know replacing the element is a simple task: my question is this- is it safe to turn the circuit breaker back on and just use the stove-top with the bake element unplugged while I order a new one. I will leave the breaker off till I get an experts opinion.
  • Thomas Simmons Dec 02, 2008
    Thanks for the quick response but the element is actually burned up and a piece broke off- am I better off leaving the power off?
    Thanks for your help..yes it does look like it's gonna take a couple of days to get the part and I don't want to cook out of the microwave until then.
    Again, I appreciate the help, Tom
  • Kitchen Ranges Master
  • 2,651 Answers
Youd be better to leave the old elemnt in tillits replaced, the wire leading to the elemnt is ALWAYS live, even when not on there is ALWAYS power to the elemnt wire
Posted on Dec 02, 2008
  • Ron Coons
    Ron Coons Dec 02, 2008
    solangas you dont touch it, and it not touching anything else,I wouldnt reccomned leaving it on indefinitley but if you need to turn on breaker to cooka meal on stove top and then shut back off, forthe 2-3 days its gonna take to get elemnt, i dont \see a problem with that. TURN OFF POER BEFORE REPLACING IT IS ALWAYS LIVE!!!
Model no. 790.97433800. Why does it trip breaker and shuts off after heating to correct temp?
Hi Patricia
Hey... the breaker has saved your life!
There can be a number of reasons for this type of fault.
The one that comes to mind for me is...
The element itself is "inside a metal sheath" which is grounded to the Earth connector in your AC Mains Box.
With heating and cooling many times an element can melt or burn through to the outside sheath. This causes a short circuit to earth which blows the circuit breaker. Thats why we ground appliances to earth.... for safety. Otherwise the whole body of the appliance would go live and give you ashock when you touch it and say "the sink" or "floor".
Generally it's pretty simply to turn off the power then lift the element up and pull it out of it's socket.
Take it to the appliance dealer and get a replacement.
Good luck
Was this Helpful... How about a Tick of Approval?
Thats our only reward....
Replacement oven elements cooker elements and oven parts
oven elements replacement
Sep 13, 2015 | Kenmore Kitchen Ranges
Will just replacing the oven element fix my Kenmore model 911.955879range oven? It sparked, broke in two and a white flame continued going around the element, wouldn't stop I had to shut breaker off.
Hello Jennifer;
My name is peter. I am a retired field service appliance technician.
Good for you - turning off the breaker.
You have a older oven. Usually there is a spark or crack in the oven element. In your case the element was so embrittled it broke into 2 pieces.
Before you use the top range burners to be on the safe side you need to disconnect the oven element. You may have damaged the oven control board to where it is locked into power for the oven.
25713262-01ium3bsyoj5ql4fhv4kpwvp-4-0.jpg 1.) Remove the bottom drawer to reduce weight.
2.) Put a rug on the floor in front of the oven, so when you pull the oven out it does not scratch the floor.
3.) Pull the oven out so you can get behind it.
4.) Unplug the unit.
5.) Remove the back bottom cover.
6.) Disconnect the heating element and remove from oven.
7.) Rap the two loose element connections in the back with electrical tape.
8.) Follow the element loose connection to the control board at the top. Disconnect at the oven control board.
9.) Inspect the loose wiring from the control board to the heating element for burns or melting.
10.) Plug the oven back in and turn on the range burners.
The part number for the oven element is WB44T10014. Sears wants about $95.00 for this part. Search the internet for this part number and get it for about $28.00.
Your oven control board may have become damaged. Recently I replace one for a friend. Sears wanted $256.00. I got a remanufactured board over the internet for $30.00.
Get back to me and let me know what is going on.
May 25, 2015 | Kitchen Ranges
The time display has gone blank. When I switch on temp dial the red oven light flickers. When I switch on fan dial nothing happens
Assure full power is available to the unit(220 volts-not 2 times the same 100 volts). Depending on the model, and age of the unit, the circuit board behind the clock is failing or has failed. The timer board directs timed power for the oven, shows the times, and may have other features. Any elements are usually directly controlled by the knobs without going thru the timer board. When the timer display disappears and stays blank no matter what you do, even turning the breaker off and then on again , then power thru the board has failed. This could be caused by mass failure of the board(burned out-burned parts-vaporized parts) right down to a couple simple components that have failed due to age and don't pass the power onto the circuit.. High voltage is present and any troubleshooting should be done by a competent person for that task. Be safe.
Apr 27, 2015 | Ovens
Wont get hot
Most likely burned out heating element. Does the broil work? If your handy turn off the circuit breaker making sure power is truly off by turning on oven to verify it won't turn on. Remove the screws from the bottom heating element remove the wires and take it to your local appliance supply house, they might test it for you and they can surely sell you a new one just by the the shape alone.
Oct 28, 2013 | GE Jrs06Skss 24" Single Electric Wall Oven...
No heat
The home's circuit breaker is not the problem if part of the stove / oven works. What is more likely to be the cause is a problem such as an "open" or "burned out" heating element or socket.
The control is "on" and sending power to the element. The control reports "Preheating" but since the heating element itself is no longer a complete circuit - it fails to heat. As mentioned above, it may be a problem with the socket that the heating element plugs into - but could be a problem with any wire between the control and the heating element.
I would suggest shuting off the circuit breaker for the stove / oven. Check to be sure it is off by turning on a heater that worked previously. If it stays off, you're ready to continue. Carefully inspect the heating element itself for damage. The surface of the heater should be uniform - smooth over the entire length. You may not be able yo view the back side of the heater - but you may be able to run your fingers gently over the surface to feel for damage. If damage is found on the surface, this would indicate that a new element is required. Once replaced, you should expect it to work again as new. If unable find damage, removal and inspection of both the oven's socket and heating element contact blades should be done. If found to be burned or damaged, replacement of the socket, heater or both may be needed.
Obtain replacement parts designed for you make and model stove / range. Contact an appliance repair service if unsure how to check / make these repairs.
I hope this helps & good luck!
Apr 27, 2013 | Bosch Kitchen Ranges
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
It would be very unlikely that both elements went out at the same time. Is it possible that one element went out a long time again and went unnoticed?
Do this: Turn your oven on BROIL and the temperature up all the way and see if the top element begins heating.
Then turn it on COOK and see if the bottom element comes on.
If both elements fail to work then your problem may be in the selector or thermostat control. You may also have a wire that has come loose (or burned loose).
If you are comfortable working with electricity, you can turn the circuit breaker off and remove the controls for testing. Also, verify that all the wires are properly attached.
If you are not comfortable, have a service technician check it out immediately. It scares me that there may be a loose wire behind the control panel!
If one of the elements worked and one did not then the problem is "most likely" a bad element. Turn off the circuit breaker to your oven and make sure all the knobs are off on the oven and you can remove the element and take it to a parts store for replacement.
It is easy to remove. Take out the wire shelves and unscrew the screws where the element goes into the back of the cooking cabinet. There will be some wires attached which should pull off.
Good Luck!
Oct 28, 2009 | Ovens
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Aug 13, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
195 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
