Question about HP Computers & Internet
I have a Compaq presario notebook computer and I can't get the number keys to work in 1 of my programs but they are working here. I've tried function and then number lock but it doesn't work.
  • HP Master
  • 4,806 Answers
The problem lies with the programme you are using at the time, go back to that applications and look for and "options" menu. You should be able to sort the problem with the software
kind regards and please don't forget to rate us
Posted on Dec 02, 2008
Compaq presario fan stopping
Take it back to the place of purchase since it is under warranty, otherwise you will damage the processor which the cooling fan protects.
May 03, 2012 | HP Compaq Presario V2310us Notebook Pc...
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
I just connected my compaq presario notebook to my hdtv and it is not working what am i doing wrong?
Without knowing the exact model number of your computer, and what connection you are using, it's hard to say. However try pressing 'Function' + 'F4' and see if you see the display on your TV (May take a few seconds to transfer the image. If you do not see an image, try pressing it again as most computers have several different display modes it can cycle through. It could also be a different 'F' key that you may need to press.
Good Luck
Apr 25, 2010 | Compaq Presario Notebook
My Fn F4 key is not working is any other option lcd connectivity
Hello
Just follow any of the method
Method 1:
  • Press Home (the 4 boxes doing the wave) then after pressing it a box should pop up, press the button R... press Enter , then watch as you computer restarts. When it is finished loading log back in and it will work, this also works for many errors and bug reports too.
Method 2:
  • Try holding down the function key and hitting the numlock or scroll lock key, this is usually how you engage or disengage the laptops function keys on the keyboard. Most laptops have a light that will turn on and off when you do this, indicationg that the funtion keys are in use. depends on the brand
Wishing you success
Mar 13, 2010 | Compaq Presario Notebook
I have a Compaq Presario CQ60 laptop and was told that I had my scroll lock activated because the numbers on my number pad only half work. The 0, ., 4, 5, 6, /, *, - all work. The 1, 2, 3, enter, 7, 8,...
Find 'fn' key (this is short for function) then find 'num lock' key in your case it must be another key with and extra label with the same font color as 'fn', this means this key behaves differently when pressed with 'fn'. When you have located both key press fn+num lock a led indicating that numeric lock is activated should go off and you're done.
Mar 04, 2010 | HP Compaq Presario CQ60Z Notebook
Numper pad usase on compaq persario Note book PC
You need to get into your SETUP routine and enable NUMPAD function
Mar 04, 2009 | Toshiba Satellite A105 Notebook
''function'' key on all the tme
number lock is probably on. press it again.
Nov 14, 2008 | Compaq Presario R3000 Notebook
Compaq C770
Your computer has a program on it called quick launch. It could be that the function key won't work until the program is loaded up into the memory of your computer.
Jul 16, 2008 | Compaq Presario 700 470024-192 Notebook
Function keys
USERS MANUAL GENIUS IF YOU THREW IT OUT DOWNLOAD IT FROM HP.COM
Oct 26, 2007 | Compaq Presario V4000 Notebook
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
