Question about GE JES1231 Microwave Oven
Non-Stick surface peeling off inside microwave.
GE Model Number JES1231 The non-stick surface inside of microwave has completely peeled off under the glass rotating plate What type of materail can I use to resurface. Would a heat resistant enamel work?
  • Anonymous Jan 26, 2009
    People have suggested putting appliance paint inside, but no one seems to know if it's actually safe to eat food that has been cooked inside of it after the appliance paint has been applied. It's heat resistant, but what happens when the paint is heated up - it's resistant, not proof so I would think that it would potentially give off paint molecules which would not be safe for food consumption.
  • Anonymous Feb 18, 2009
    Same thing with paint peeling off. I tried the appliance paint and resurfaced the bottom of the GE Microwave. It worked for about 8 months, then it began peeling away again. The rust got so bad we ended up trashing the unit and replaced it with another GE microwave-Model# JES1456. But I have lost faith in GE. First our 2-year-old GE Profile Refrigerator's motherboard died Septemeber 2008 and it took over a month to get that resolved, and now our 2-1/2 year-old GE Microwave JES1456 just blew-out the magnetron...a $250 repair! I am sending it to Jeffrey Immelt, CEO of GE, along with an angry letter, since GE has no provisions to recycle their products like other more environmentally responsible companies such as Dell.
    Jeff
  • GE Master
  • 9,156 Answers
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Posted on Jan 29, 2007
I've got a badly scratched touchpad membrance from abrasive sponge - lesson learned the hard way. Anyways, how do I replace the touch pad membrane on a Kenmore Microwave Model # 721.80049700? I&
I am not familiar with that specific model but typically touch pads either come as an assembly or as just the membrane that has a peel off paper on the back that covers a sticky layer that sticks onto the metal frame inside your unit. If that is the case, you have to remove the old touch pad and take a screw driver or a knife and start at one end and lift it off of the frame, once peeled off, clean the metal frame with laquer thinner to remove the old adhesive, make sure it is dried completely and then take off the protective paper of the new pad and stick it to the frame. If it is a plastic frame you CANNOT use a solvent like laquer thinner as it will melt the plastic frame and destroy it. On those I tend to just drag a razor blade across the surface until I feel it is clean enough to mount the new one. You could use alcohol to clean it. Or possibly mineral spirits. You jsut want it to be perfectly clean and grease free
Oct 02, 2017 | Microwave Ovens
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
Feb 10, 2012 | GE Microwave Ovens
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
I have a black sticky residue on the non stick surface of my cooks essentials 12 inch frying pan. I can not clean it off and the non stick properties of the pan is gone, I think due to this surface...
Go to epinions.com, type your product and find you are not alone. Besides, as there is no cure to baldness there is no such thing as a perennial non stick pan. All coatings invented eventually succumbs to the wear and tear produced by temperature changes, contact with food and related chemistry, detergents, scrapping, etc. Consider the possibility that some of that non stick material may be ingested unconsciously.
Dec 18, 2010 | Microwave Ovens
On the inside of the door of my microwave front window is an adhesive plastic covering that if you pull it off there is a black mesh screen exposed. is that clear sheet suppose to be removed.
The metal mesh is a filter screen to keep the microwaves in the oven while letting you see the food. The plastic sheet that's peeling off is meant to keep that screen clean. It's not supposed to be removed, since then food can get into the holes in the screen. A buildup of foods can lead to overheating and burn the paint and possibly damage the door. It should be replaced.
The part number is WB36X10068. A Google search turned up several sources. Here's one, but there are others. The new sheet has the adhesive applied, you just peel off the protective film and stick it in place. Clean the door inner surface first so the new sheet will stick firmly.
Good luck with the repair, and thanks for using Fixya!
Oct 17, 2010 | Hotpoint RVM1435 Microwave Oven
Kenmore microwave model number 401.80084700 Displaying -SE-/-5E-
-SE- error means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There are three ways you can get it fixed:
DE34-00178X SWITCH MEMBRANE $20.30
ref#53 membrane keypad
take yours off as in the video at our site, peel the old keypad off as in this handy guide with pictures , clean the surface, stick on the new keypad
order by part number here
(We can do this job for you for a total of $70.25, but as you can see, the other two options are more practical and economical)
DE94-01647A ASY CONTROL PANEL $39.01
ref#66 control panel frame with keypad
take yours off as in the video at our site, disconnect the keypad strip as shown here, move your circuit board to the new frame, reinstall
DE94-01648A ASY CONTROL, BOX $58.12
ref#59 complete control panel assembly with frame, keypad and circuit board
take yours off as in the video at our site, then install the new one
If these parts are not in stock, they should be available in about a week or so.
Aug 06, 2009 | Kenmore Microwave Ovens
Small tear on plastic lining covering the inside of the door
That clear cover (sometimes called the inner door screen) is very important.
It protects the metal mesh / screen from debris and corrosion. The metal screen allows you to see "what's cooking" (*grin*) but prevents microwaves from leaking out of the door due to the precise size of the openings in the mesh.
If the mesh rusts or gets grease or food on it, it can arc, and this can damage the screen, then microwaves can leak, causing a burn or fire hazard. (No "radiation" threat, though)
If no arcing or other damage has occurred yet, you can clean the area squeaky with alcohol, then dry it completely and use the smallest possible amount of clear Scotch tape or packing tape to cover the tear and make sure it's flat.
If this fix doesn't work, or it's too big an area, you will have to replace the sheet, which can be ordered.
You'd have to heat it up with a hair dryer, peel it off slowly, then clean the area with something like acetone, then peel and stick the new one.
If you need to or prefer to order it, I would need your brand and model number to help you further.
Oct 05, 2008 | Microwave Ovens
JVM1740SM1SS
Your membrane keypad has probably failed.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
(Remove the grille from across the top, remove the top screw in the control panel frame, then lift up & out).
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off.
You have to make sure all the old adhesive is off or the new keypad will not stick.
I use paint thinner or mineral spirits, then follow up with isopropyl alcohol to be sure the panel face is squeaky clean and dry.
Then peel the backing paper from the new keypad and carefully press the new keypad in place.
You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Jun 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Model GE JVM1631CJ01
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Essentially you unplug the oven, remove the grille, remove the control panel, unplug the keypad, peel it off, then stick the new one on. This is of course an oversimplificaton and is not intended as a substitute for proper safety and disassembly information.
Aug 27, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JES1231 Microwave Oven Logo
386 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
